exhaust help
Old Dec 31, 2010 | 02:20 AM
kennymo's Avatar
exhaust help
i am going to be trying out some different exhaust setups in the near future to try and find the "perfect" sound for ME. but i have a question first.
is there a such thing as mounting the muffler TOO close to the engine? for example mounting the muffler RIGHT after the y-pipe. i dont know if it will create back pressure to soon or if it will be a bad thing.
Old Dec 31, 2010 | 02:26 AM
Project's Avatar
Just my .02 but an exhaust is so far away to lessen the sound in the car and also take heat away from the undercarriage to keep the inside of the car cooler. More of an overall making the car more appealing to the normal driver and not the sports enthusiast.
Old Dec 31, 2010 | 02:29 AM
kennymo's Avatar
well i wouldnt just leave it cut off after the muffler. i would still run a pipe all the way out the back
Old Dec 31, 2010 | 02:32 AM
Project's Avatar
I know what you mean or just open dump it. Summit offers weld in or bolt in dumps that are controlled electronically or manually.
Old Dec 31, 2010 | 02:35 AM
kennymo's Avatar
i actually already have an electric cutout sitting in the garage. my main concern with the hole thing though is that i will mess something up by having the muffler so close.
Old Dec 31, 2010 | 02:37 AM
Hotdawwgman's Avatar
I believe it may create more back pressure if I am correct....
Old Dec 31, 2010 | 02:41 AM
kennymo's Avatar
is that bad? i would be using a muffler with 3'' inlet/outlet if that makes a difference
Old Dec 31, 2010 | 02:49 AM
Project's Avatar
http://www.nsxprime.com/FAQ/Miscella...austtheory.htm
Good read.
Old Dec 31, 2010 | 02:55 AM
Jairen's Avatar
First off, what y-pipe are you using? What other plans do you have for an exhaust? Single, dual, cut-out, cut-out location, etc.
There's nothing wrong with mounting the muffler after the y-pipe. A lot of aftermarket exhausts actually mount pre-mufflers or resonators around that area.
Look at Motordyne's exhaust systems. It has a muffler right after the Y-Pipe.
Old Dec 31, 2010 | 03:07 AM
kennymo's Avatar
i have the nismo y pipe. ill be doing a single in single out RIGHT after the y-pipe, then 3 inch piping all the way out the back.
from that link that project posted i dont think i will have any problems
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Albanian122
Sep 12, 2015 04:02 PM
