Intake Comparison....what works!
Old 05-12-2011, 09:51 AM
DaveB's Avatar
Originally Posted by Jeff92se
Um the back halves and the panel filters are almost identical inbetween the Z and G. They are NOT completely different. In fact, the Z and G use the exact same panel filter
Also, the G airbox also has an extra intake inlet which effectively doubles the inlet size compared to the Z's airbox. There's no shortage of air being provided to either box. The sole reason for the Z's design is to create a decent amount of induction noise.
Old 10-05-2011, 09:06 AM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
Originally Posted by JJSOLON
If I remember right you have said positive things about the stillen intake as well in the past. Correct?
Stillens CAI is probably the only intake that isn't bothered by heat and then there's the advantage of having that giant K&N filter.
Gary, I think you are influence by the fact that you run the same fujita as the mag. Sorry but I put a ton more faith into what Hydrazine has found than some magazine.
What makes the Fujita so special? It's just another how air intake like all the others that fail to perform on the G/Z
Jeff actually I'm only influenced by what I use and like along with the results. I run both the Stillen CAI/Z-Tube intake and then switch to my Fujita for meets cause it's extreemly beautiful....
Gary
Old 10-06-2011, 02:52 PM
Jbatista's Avatar
Is the K&N air filter better to run along with the ztube rather than leaving the stock paper filter in? Im buying a ztube shortly and trying to figure out what goes best with it.
Old 10-06-2011, 08:52 PM
KingCobra's Avatar
^ yes sir, anything is better than stock filters....i went with the Apexi filter for mine since I believe the K&N you would have to oil every few months after cleaning it..
Old 10-08-2011, 05:18 PM
gary c's Avatar
Having used twin K&N filters on my last '92 300ZXTT with 500 rwhp until I sold in in '2K4 those filters only need cleaning every 5K miles which to me was every second oil change. Following the instructions they get cleaned/dried out/oiled in an hour.
Gary
ghost_g35
08-07-2015 10:31 AM
newg37
07-26-2015 09:32 AM
netcbc
Engine - Intake/Fuel CDN
07-24-2015 02:21 PM
quickspeed6
24
07-15-2015 11:06 AM
Quick Reply: Intake Comparison....what works!
