The Most Quiet HFC?
Old May 27, 2011 | 07:06 PM
The-Dream's Avatar
The Most Quiet HFC?
List em boys.
Old May 30, 2011 | 11:36 PM
dcityjatt's Avatar
oem cats
edit: ah damn it, you said hfc's
Old May 31, 2011 | 07:23 AM
Blue Dream's Avatar
I drove ttrank's car solo
In for the replies, I'm curious as well.
Old May 31, 2011 | 08:32 AM
doeboy's Avatar
I just bought the new ART V2 pipes, I know there not HFC's but they are way quieter than my Megan Test pipes I had on prior and it feels like it pulls more in the lower RPM's. Definitely worth looking into
Old May 31, 2011 | 09:28 AM
SDGenius's Avatar
do you mean the least raspy? because w/different exhausts it'd be pretty tough to say what one is quietest.
Old Jun 1, 2011 | 05:12 PM
Hydrazine's Avatar
ART pipes combined with the XYZ HFC.
Old Jun 1, 2011 | 09:04 PM
The-Dream's Avatar
I thought ART pipes replaces the HFC?
Old Jun 1, 2011 | 09:08 PM
CandlestickPark's Avatar
ill Sedan
The MD XYZ pipe (Y-pipe) has a HFC that attaches to it.
Check it out here under exhaust components.
http://www.motordyneengineering.com
Old Jun 2, 2011 | 12:19 AM
The-Dream's Avatar
I want to go ART but I can't pass emissions with it. Also I'm ordering the ARK Grip exhaust so I can't use the Y-Pipe. At least I think!
Old Jun 2, 2011 | 02:25 AM
KingCobra's Avatar
HFC attached to ART pipes? Wouldn't that defeat the purpose of the ART pipes?
Old Jun 2, 2011 | 06:21 AM
doeboy's Avatar
you could swap it in and out with his other attachments if you needed to pass emissions or wanted it to be real quiet.
Old Jun 2, 2011 | 09:15 AM
Hydrazine's Avatar
Nope.
If the HFC is relocated further downstream like how its done on the XYZ pipe you end up making more power and its quieter too.
Old Jun 2, 2011 | 01:49 PM
KingCobra's Avatar
Nope.
I see...but ART pipes alone are still the optimal setup correct?
Old Jun 2, 2011 | 02:03 PM
jamestown's Avatar
Optimal is subjective to what you are trying to achieve. If you want the most output then the cost is noise and emissions. If you need to run cats for some reason the art plus xyz pipe with hfc module is a great option.
Video Share
Jan 31, 2017 04:00 PM
DRG35R
Sep 16, 2015 05:33 AM
vstring
Sep 11, 2015 02:50 PM
