Exoticspeed RII-Titan Exhaust or the MD shockwave dual V2 TDX . HELP
Old Dec 13, 2011 | 05:36 PM
saason.Ez's Avatar
Okay so i been doing some more research and i found another exhaust around the same price as the MD one... haven't heard that much about it wanted to know everyones take on the Exoticspeed RII-Titan Exhaust---> LINK http://www.exoticspeed.ca/product_info.php?products_id=4921{71}684{73}689
I can't decide between the Exoticspeed RII-Titan Exhaust or the MD shockwave dual V2 TDX
Which one would you say would be louder and does the Exoticspeed RII-Titan Exhaust have the options of adding the XYZ or Art Pipes to it. ?
Old Dec 13, 2011 | 08:03 PM
g35sleeper123's Avatar
If you want a really cheap one get an xo2 and just add better tips
Old Dec 14, 2011 | 09:40 AM
KnowScott's Avatar
MD without a doubt.
Old Dec 14, 2011 | 09:44 AM
KnowScott's Avatar
Only two exhausts are on my list... MD and Fast Intentions Intimidator
Old Dec 14, 2011 | 12:27 PM
MUMM RA's Avatar
I'm stuck between these two exhausts too. I know the MD exhaust performs and from what I've heard on youtube, sounds like sex. I've heard a few exhaust clips of exoticspeeds exhaust and it sounds great too. These two exhausts are what I narrowed my choices to. I need help with this guys!
Old Dec 14, 2011 | 12:48 PM
saason.Ez's Avatar
yea exactly maybe comparing specs of the two so hard to decide... i was wondering with the Titan II can you include MD accessories like the XYZ w. straight pipes? or ART pipes?
Old Dec 14, 2011 | 12:58 PM
IP_G35_MSR's Avatar
^^+1 On the MD
Old Dec 14, 2011 | 01:51 PM
Yeah the MD sounds greaet
Old Dec 14, 2011 | 01:57 PM
viceversa's Avatar
jesus christ....
No you cannot use the Motherdyne XYZ pipe with the Exoticspeed Titan II b/c of the dual midpipes immediatly after the y-pipe...you will have to use the included exoticspeed y pipe with that exhaust.
Yes you can use the ART pipes (test pipes) as they come before the y-pipe.
If you want to use the Motordyne XYZ pipe with an exoticspeed exhaust then look into the R1 or R1-T which is a 3 inch single exhaust which splits into dual mufflers at the axle back seciton. With that you could pair up the MD XYZ pipe (along with any accesories) and connect that directly to the mid-pipe of the exoticspeed system...like I did
Old Dec 14, 2011 | 02:12 PM
HenryLee's Avatar
I say MotorDyne. But im bias since I have a MD Gamma dual.
Old Dec 14, 2011 | 05:05 PM
saason.Ez's Avatar
Originally Posted by viceversa
jesus christ....
Cleared that up perfectly thanks! So if I'm looking for a louder setup what would you recommend
stick to the TDX V2 w.arts Or do your method of of getting the R1 and pairing it with xyz and accessories from MD.
Old Dec 14, 2011 | 10:20 PM
PR-G35Driver's Avatar
my friend has a z but its the same platform with the exception of a shorter exhaust. hes running berk high flow cats with motordyne tdx v2 and at idle its really deep and kind of bubbly, the take off is what u would expect from what seen on all the youtube videos already made.
i would say get the sg-longtubeheader and motordyne tdx v2 combo but sg closed down and the price for the headers isn't for everyone
Old Dec 16, 2011 | 08:58 AM
viceversa's Avatar
not sure how loud the TDX with ARTS is as I've never heard it in person. My setup right now which is. fast intentions resonated test pipes, MD xyz pipe with straight thru piece, and exoticspeed R1-T is not really that loud for cruising around but sounds pretty mean when you get on it. The ability to change that sound to a more deeper tone using the resonated XYZ accessory is also a plus.
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
danielidiaz13
Engine - Exhaust
Sep 22, 2015 02:57 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
Julianpnce
Engine - Exhaust
Sep 14, 2015 01:11 AM
Spartan268
Aug 20, 2015 09:14 PM
