newest version Art pipes
Old 12-18-2011, 10:36 PM
Aztec's Avatar
I was serching a saw this post and it also sounds like 1000 bees in a coffee can...
https://g35driver.com/forums/g35-sed...arrived-2.html
If its only rasp then I can live with it. I'm getting the XYZ pipe with resonator so it should fix the rasp..
I see what uprev tells me. I'll keep y'all posted..
Old 12-18-2011, 10:38 PM
Aztec's Avatar
Originally Posted by skidz88
Hopefully it's just your heat shield bolt causing the buzz. I'm a 6MT and still get a buzz between 3-3.3k rpm...it's one of the reasons I'm ditching the ART pipes in the spring. Can't seem to find a fix, sound is coming from inside of mine.
You should try the XYZ with resonator and see what it does first...
Old 12-19-2011, 09:47 PM
Aztec's Avatar
rick said for me to come and he will look at it. Ill try to go by Thursday or Friday.
Ill keep y'all posted...
Old 12-19-2011, 11:21 PM
akaneedles's Avatar
Yea,its the bolt above the drivers side pipe.Was getting that noise to under load.So Jacked up the car and found that bolt(Didnt know MD tells you to cut it) Its very close to the pipe.Once I cut it ,no more noise.
Old 12-20-2011, 12:14 AM
Aztec's Avatar
Do you have to take off the art pipe to get to the bolt? If you don't need to take out , the. I can do it my self...
Old 12-20-2011, 07:37 AM
akaneedles's Avatar
No, I didn't . Had a little hack saw. It's tight , but I didn't take the pipe off
Old 12-22-2011, 12:33 AM
Hydrazine's Avatar
No, you don't need to take them off. You can do it with a bolt cutter, dremel cut off wheel or even with a pair of heavy gauge wire cutters.
Its a ~1/8" thick stud that pokes down from the floor board.
Old 12-22-2011, 01:07 AM
Aztec's Avatar
Cool , I will try it to do it this Sunday, hopefully I don't drink too much on Xmas eve. Lol.
Old 12-27-2011, 07:47 PM
Aztec's Avatar
update...
Yesterday i check why it was buzzing and i also change the oil at the same time, but its not the heat shield bolt. upRev did cut that bolt off....
The only think that i could tell was the art pipe does hit the heat shield it self where there is a 90 degrees angle....
I also saw water or condensation where the art pipe and y pipe meet up, it was dripping a fair amont, not a constant amount but its noticeable,,, don't know if that is normal or what......
(engine was cold, i was changing the oil)
But i haven't been hearing the buzzing a lot. Maybe one or twice every few days or so, or even once every 3 days....
But im keeping the art pipes, they are amazing..
Ill see what upRev tells me about water dripping by the art pipe and y pipe...
ill keep yall posted.
Old 01-21-2012, 08:56 PM
Aztec's Avatar
i installed the xyz with the resonator today, i had rasp when i went over 3k with the stock y pipe, the rasp is gone now. Sounds amazing now.
Old 01-21-2012, 09:45 PM
Frankieg35's Avatar
Any sound clips?? U have stock exhaust with xyz and art pipes??
Old 01-21-2012, 10:07 PM
Aztec's Avatar
lll try to upload sound clips. The only thing i have is my iPhone 4s. Don't know if the quality will be good.
Yeah i only have stock exhaust. I don't know if I'm going to do anything else to the exhaust.
In a few months I'm gong to put a high end sq sound system so my exhaust cant be too loud.
But i will be adding a z-tube, 06-07 air box and MD 5/16 spacer and lastly a upRev tune in a few weeks, so stay tune....
Old 01-22-2012, 12:25 AM
Frankieg35's Avatar
Id like to do those same intake and exhaust mods as u..
Old 01-23-2012, 10:09 AM
yusoslo's Avatar
love to hear a vid
  #30
Old 01-23-2012, 11:50 AM
KnowScott's Avatar
in for vid
Quick Reply: newest version Art pipes
