anyone try AEM's ETI intake?
Old Jan 21, 2012 | 11:32 PM
funnyscreenname's Avatar
so i was browsing around at items for sale on another forum and i saw someone selling an aem eti intake tube and the maf tuner. it said it was for 03-06 z's. i started checking out aem's site and basically it looks like the "tuner" makes the ecu not react badly from the change in air flow. like it won't cause the fuel mixture to become lean if a smaller/ larger size tube is added. i didn't really see anything about using this on a g but, if it's for the vq35de then i don't see what the problem would be. i tried searching on here and didn't find much on the subject. has anyone on here tried this or have any experience with the aem eti intake or maf "tuner." i'd like to check out the little tuner deal because if it does tell the ecu your engine has better air flow and makes the correct changes without compromising the fuel mixture then it should really increase hp.
Old Feb 6, 2012 | 05:53 PM
jc2310's Avatar
Hi guys,
I have Fujitsubo exhaust and will be placing exoticspeed y pipe soon, leaning on getting the Berk HFC's, can anyone see any issues on the issue and would I need to get the car tuned? or will the ECU need resetting once I install the Berk HFC and the Exotic Speed Y pipe. Thoughts and suggestion would be much appreciated.
Thanks in advance all
Cheers
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
