Intakes and AF Mixture
Old Feb 10, 2012 | 08:16 PM
JUST1NSANE's Avatar
Hey guys & girls,
I just bought an 06 G35 coupe with a rev up motor. I have done a lot of research and I am ordering a Motordyne MREV2 lower plenum, either a Stillen short ram(w/box) or induction, and I already have my Motordyne 5/16" spacer. Has anyone tested to see if this makes the VQ run lean or will my OEM MAF sensor correct the mixture with those mods?
Old Feb 11, 2012 | 07:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
You'll be running a little lean if you're still on the stock exhaust and the ECU won't be able to compensate. If you add an exhaust and/or HFC/test pipes you'll be running dangerously lean and would need a custom tune like Osiris to fix your AFR.
Old Feb 11, 2012 | 07:17 AM
Shanes_G's Avatar
im running dangerously lean. and im scared.
Old Feb 11, 2012 | 07:18 AM
Shanes_G's Avatar
i need to tune my car asap. i need to try to keep my rpms down. but its so hard bc i love my exhaust.
Old Feb 11, 2012 | 08:16 AM
Blue Dream's Avatar
Yep you definitely need a tune. Just remember that at high RPMs you run the risk of knock and detonation that can seriously damage your engine.
Old Feb 11, 2012 | 09:18 AM
JUST1NSANE's Avatar
Is there not any cheaper way than the Osiris Tuner? I just checked and that ish is $699 for my rev up. What about just the MREV2 Lower plenum and spacer with a stock intake with z tube, still lean? I hate that just 2-3 mods make it run too lean for the ECU to compensate I really just want it to be reliable and not have problems. I want to do it the right way and keep the car from having problems especially at higher RPMs.
Old Feb 11, 2012 | 12:33 PM
b_moneyy's Avatar
That setup will run a bit lean but unless you throw exhaust and replace the cats with hfc or especially test pipes, your car will be just fine without a tune. One other thing, when or if you decide to get a tune, its best to get it Dyno tuned at an uprev licensed shop, should be cheaper then 699 and your gains will be maximized.
Old Feb 17, 2012 | 06:25 AM
CaseyinGA's Avatar
Will a Jwt short ram, polished z tube, Megan racing resonated test pipes, 02 sensor extenders, and cat back exhaust. I'm dangerously lean? Crap!!!
Old Feb 21, 2012 | 03:13 PM
Sparda1123's Avatar
Damn i kind of hoped it wasnt too lean but reading this i need a tune asap im on headers, test pipes, cat-back, intake and spacer
Old Apr 29, 2012 | 07:36 PM
tt awd's Avatar
So looking at this thread its safe to say with the following mods i would be running quite lean without a tune on my 05 coupe
Alphawerks headers
FI exhaust
FI test pipes
Mrev2
Spacer
ztube
If i keep it in the lower rpm range i should be fine though?
Old Apr 29, 2012 | 08:46 PM
seymore4's Avatar
m56
You will be running like dick and won't be getting half the performance you should be. You need a tune.
Just check up on this thread
https://g35driver.com/forums/tuner-d...heets-ftw.html
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
