Cleaned throttle body now problems :( help
I cleaned the throttle body since my car had ses light. I put everything back to place and started the G and sounds like crap sounds like cats are clogged and high iddles when car turns on. I need your help asap I'm not even driving it
Whata really bothering me is the the exhaust air flow is having trouble its like something is clogged or something it even pops at times. All this happened when I put everything together and turned car on. I drove it down street and the air flow is horrible when I step on it like its trying fight thru
Maybe you're timing during the procedure is a little off. Make sure you use a stop watch or something rather than relying on counting out loud. You're car wasn't running sh*tty before you messed with the TB right?
no it wasnt it was running great like the exhaust sounded normal now sounds horrible alot pops and rumble like its fighting air flow. I just wanted to clean the tb since the idle was lil funny now I wish I left it alone
Then I would keep trying the reset procedures. Some people can do it in 5 mins, some people needed 2 hours lol. Did you touch the MAF at all? I'm assuming you read the other TB cleaning threads?
Edit: make sure you're car is at operating temperature. i.e. drive around for 10 mins or so pull in, then start the reset procedure. You can sit in your car all day and execute perfect timing during the reset but if you're car is cold you won't have any success. However, the ECU reset can be performed when car is cold.
Ya I cleaned the maf and tb. Thanks man ima do that when I get home hopefully it would get rid off that rumble air flow off my exhaust like it didnt have before I mess with the stuff thanks man
