fitment issues w/ crawford high flow cat?
Old Jan 18, 2005 | 09:09 PM
StVincent's Avatar
does anyone with Crawford high flow cats have a fitment problem? i just had them installed from my friend's shop. after installation, i immediately noticed the rattle, noise rubbing against the metal under accelaration. there was no CEL, no leaking. when i took it back, my friend told me the cat is too close to the engine, barely has enough space. so when i accelerate, engine is slightly moving side to side touching the cat to cause that rattle. they tried to readjust them, taking them apart and back in, but they couldn't resolve the problem, and there was no way they could bend them. i need some inputs, whenever i drive my car, it feels so cheap.. any help will be appreciated..
Old Jan 18, 2005 | 09:44 PM
SI_G35Coupe's Avatar
i think maybe this is an issue with 2004 coupes, because my Kinetix cats had the same problem. i am getting crawfords installed in a few days, so i'll ask my tuner about this.
Old Jan 18, 2005 | 09:46 PM
lowrider's Avatar
No problems at all with mine. Fit like a glove. This is the first I've heard of anyone with fitment issues with the Crawfords.
Lou
Old Jan 18, 2005 | 11:22 PM
StVincent's Avatar
have you contacted the kinetix?
*lowrider* i did my search before i jump on this, but never heard of fitment issue either..
Old Jan 18, 2005 | 11:30 PM
StVincent's Avatar
sorry forgot to mention.. i have slight odor, burning smell coming through vent, and idle is a bit lower than normal. is this normal? i haven't reset the ecu yet.
Old Jan 19, 2005 | 05:47 PM
i contacted kinetix, they told me i got an early set that didn't fit right...
i had the exact problem that StVincent is describing
ultimately the right side one split and is leaking, so i'm sending them back for a brand new set (am switching to Crawfords anyway)
and my idle did drop slightly when i installed my high flow cats also
Old Jan 28, 2005 | 10:01 AM
CrazyMike's Avatar
SI - did you ever get the Crawfords installed?
Old Jan 28, 2005 | 09:06 PM
StVincent's Avatar
i contacted the Crawford crew, they said it's just the heat shield right underneath the frame, i confirmed this with my mechanic too. they told me g35c's heatshield is sitting lower than 350z for some reason, all i need to do is bend it. weather's been too cold lately, i haven't try this yet, but i think it will solve the problem.
Old Jan 29, 2005 | 10:20 AM
got everything done this past wednesday...
the combo of the TopSpeed/Pro1 headers, Crawford Cats, and Fujitsubo Y-pipe definitely added some giddy-up to the car.
i also no longer have the vibration issues that plagued my Kinetix cats. the only time i get a vibration now is right when i cold start the car. i guess the Crawfords do fit better.
KruZZe
Feb 27, 2023 05:04 PM
magnetism80
Jan 27, 2016 12:57 PM
the93owner
Oct 4, 2015 09:40 AM
vamarris
Sep 26, 2015 12:56 PM
twentyeggs
Sep 11, 2015 03:58 PM
