Exhaust Guros, School me on some X-pipes
Old Jul 8, 2013 | 12:52 PM
Ginevan's Avatar
What's so great about them? Why do people buy them? I have a True Dual, what would the advantage be to me?
Are they just sound or does something scientific go on in that sexy X-section?
I highly doubt there's anything more than sound difference in them, but I figure I'd ask.
Old Jul 8, 2013 | 01:02 PM
Jeff92se's Avatar
Red Card Crew
X pipes scavange exhaust from each set of exhaust pipes. Improving torque, hp and sound. I ran a borla true dual with my old sedan and added a resonated Magnaflow X pipe. Reduced the DRONE by quite a bit and improve the torque/hp a bit.
Old Jul 8, 2013 | 01:04 PM
Ginevan's Avatar
Thank you for the response. Please clarify as to what you mean by "Scavenge exhaust from each set of pipes"
Old Jul 8, 2013 | 01:22 PM
Jeff92se's Avatar
Red Card Crew
True dual = two 3 cylinder exhaust systems
X pipe = Brings those two systems together to work like a 6 cylinder
Here's my write up on my borla install and the x pipe install later on. ie.. page 3 gets to the x pipe stuff
https://g35driver.com/forums/intake-...ll-review.html
Old Jul 8, 2013 | 03:28 PM
Ginevan's Avatar
I know the difference between the two, I'm pretty mechanically inclined.
So what I gather from your post, and again thank you for posting, is that the X-pipe does a better job in true dual systems to equalize pressure between both banks. In other words if for some reason your exhaust pressure is 3psi from 1/3/5 and 2.5psi from 2/4/6, the should, in theory, be brought to 2.75 each while keeping smooth exhaust flow and no dramatic changes in exhaust gas.
Thanks again!
Old Jul 8, 2013 | 03:37 PM
Xet's Avatar
Xet
For most exhausts, bar any major issues with their design, the x pipe isn't going to give you better power. It will cut down on drone/change the tone of the exhaust though.
Old Jul 8, 2013 | 03:43 PM
Jeff92se's Avatar
Red Card Crew
X pipe or H pipe will help a dual exhaust that doesn't have any connecting pipes. I both hp/torque and drone reduction (if you use a resonated version)
Old Jul 8, 2013 | 03:44 PM
Jeff92se's Avatar
Red Card Crew
Thanks again!
I do believe that the X pipe will help pull the exhaust though the pipes to help the scavenging effect and help maintain exhaust gas velocity
Old Jul 8, 2013 | 04:16 PM
Diode Dynamics's Avatar
Here is a little info from autoanything.com
http://www.autoanything.com/exhausts...pipe-vs-h-pipe
Has some decent info, keeps it pretty brief.
-Nick C.
Old Jul 8, 2013 | 04:20 PM
I don't know the sound comparisons on a G35, but with mustangs people often say X-pipes give you a racier high pitched sound and you make more power in the higher rpms vs. an H-pipe that gives a deeper, lower tone with more hp/tq at lower rpms
-Nick C.
Old Jul 9, 2013 | 03:24 PM
Ginevan's Avatar
Thanks guys!
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
