Larger 3" MAF Housing + 3 inch intake
Old Jan 6, 2014 | 02:45 AM
ARETHT3's Avatar
Been doing some reasearch.... Looking at simple logic here... Wanting to open my intake up to 3" all the way from the pod filter. Thinking of buying a 3" or even 3.5" MAF housing, 3" intake pipe then hook it up to the NWP 75mm throttle body...
http://www.treadstoneperformance.com...+Hitachi+Style
Anyone done similar i understand a tune is required will a Uprev tune me able to adjust MAF readings?
Logic bigger intake more air more power??
Any info would be great
Old Jan 6, 2014 | 06:46 AM
jdm-v35's Avatar
uprev can tune for these changes but since the plenum neck is still smaller, it probably won't net much gain for the price of all the components. Plus, to take full advantage you'd need headers, exhaust, and most likely cams with a proper tune for still minimal gains.
Old Jan 6, 2014 | 08:05 AM
Urbanengineer's Avatar
This would sound like a monster up front though. With the 1/2" spacer and tune it should increase your top end well. Talk to the forum tuners like Seymore4 for more info.
Old Jan 6, 2014 | 10:22 AM
OBsessed's Avatar
You can go larger than 3" and there are good reasons to. I'm running a 3.5" intake/MAF housing through a ported NWP Throttle Body and ported Kinetix Velocity. Needs to be retuned at 3.5" of course, 3" isn't much bigger than stock (my Z tube's ID was 2.8") and shouldn't require a tune. I know quite a few guys running 3.5s and a couple running 4" intake tubes, all through larger throttle bodies. Even on a stock TB you'll see some increase in airflow but you'll lose a little velocity as it bottle necks down at the TB. There's enough material on the TB edge of the stock plenum (and most of the aftermarkets as well) to port that opening to match a larger TB and smooth the transition from 3+ down.
Old Jan 11, 2014 | 07:26 PM
Phontain's Avatar
Where can I find larger intake tubes?
Old Jan 12, 2014 | 08:27 PM
OBsessed's Avatar
There was a limited run of them made and sold not long ago so keep an eye out on the marketplace / Facebook groups for one to pop up.
Or make one.
Old Feb 2, 2014 | 01:51 PM
arock292's Avatar
Who ported your NWP Throttle body for you and to what size did you go to? Just wondering cause I wanted to do the same things.
Thanks
Old Feb 13, 2014 | 03:50 PM
OBsessed's Avatar
Damn I never saw this, sorry man. I had my throttle body, kinetix velocity and lower runners all ported by a buddy in Texas. I don't know if he's still very interested in doing more because some guys have been ****** about sending their parts in and he's staying busy on Mopar stuff. The throttle body is almost 79mm on the MAF side and about 77 on the Kinetix side as that's all he felt safe to take out of the Kinetix. There was plenty of room to move more air through the adapter but I think he was worried about making the Velocity's walls too thin and stopped there. Really this should be pretty easy to replicate by a good machine shop, while I'd recommend my guy in a heart beat I've gotten the impression he doesn't want to deal with VQ guys anymore lol.
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
