Does It matter which Y-pipe you use????
Old Feb 14, 2005 | 03:07 PM
Sundeviljay's Avatar
I know that there are many different brand name y-pipes...Does anyone know if it matters which one you use? Do y-pipes perform similarly no matter which brand or do some brands perform better than others? Also, does it make a difference which exhaust you are using?
Old Feb 15, 2005 | 10:49 AM
Gsedan35's Avatar
Their are a lot of copies of the Fuji out their, not the best design however. Look into the Tanabe or the Jic design. You'll still have a issue regarding how they use a 3" output and your oem exhaust is 2.5".
Old Feb 15, 2005 | 11:51 AM
roro's Avatar
will the ones for the 350Z/G35c fit on the sedan as a direct bolt on?
Old Feb 15, 2005 | 12:09 PM
Gsedan35's Avatar
Yes, Y-pipe's are the same between all the cars. Down stream, the Z oem mid pipe is shorter however.
Video Share
Jan 31, 2017 04:00 PM
Fox843
Nov 7, 2015 05:43 PM
Moskvitch
Sep 14, 2015 10:15 AM
