Factory Exhaust mod?!? Remove resonators?
Old May 24, 2015 | 05:49 PM
BlueBelleG35x's Avatar
So I love the sound/tone of Infiniti' an my g35. I'd like to have it a little louder an a little more perform. I found a big resonator under around the rear door area an wonder if removal or it would give what I'm looking for an then change muffler. Any feed back would be awesome!
Old May 24, 2015 | 10:56 PM
eazdaskeez's Avatar
I'm sure it would be very raspy if you did that, I would consider removing the muffler and welding a straight pipe in place. You can YouTube it to give you and idea. Or you can get a coupe midpipe to give you a bit more sound.
Old May 24, 2015 | 11:18 PM
ScraggleRock's Avatar
Yeah, because the muffler is fiberglass packed, the resonator is there to smooth out the sound. However, if you removed the resonator and replaced the muffler with a straight thru aftermarket muffler with the same in/out configuration (like a magnaflow or borla or something), it would alleviate most of the rasp.
Either way, removing the resonator is a good idea for performance sake due to a less turbulant exhaust path, but it would most likely sound like a$$ with the stock muffler.
I basically did this with my coupe: remove resonator, replace the new section with straight pipe, switch muffler to a magnaflow muffler, and get all the intake mods (k&n panel filter, 5/16 spacer, ztube). It basically sounds like an amplified version of the stock system, but also gives MUCH better flow. It has some drone without the intake mods, however, that virtually disappears when you add the spacer, tube and filter.
Old May 24, 2015 | 11:53 PM
Lartytiejdke3's Avatar
Correct answer here is
Nismo exhaust
It will be the perfect setup to amplify the stock note
Not chop the exhaust up and fab up a poverty, sounds different so it must be better, exhaust
Old May 25, 2015 | 12:01 AM
Nismo exhaust
Damn, bro.
Old May 25, 2015 | 12:02 AM
eazdaskeez's Avatar
Sound is objective to the ears hearing it. To the op you have a few options to consider. So it's up to you.
Old May 25, 2015 | 12:03 AM
No not comin at you lol
Sorry haha
You know the "exhaust mods" I'm referring to lol
Old May 25, 2015 | 12:18 AM
Sorry haha
Much love
Old May 25, 2015 | 12:30 AM
Originally Posted by ScraggleRock
Much love
Truth
Until somebody mentions "best drummer"
Haha
Old Jul 21, 2015 | 10:35 AM
Sorry haven't returned to the thread in awhile but appreciate all the love guys.
Old Jul 21, 2015 | 11:03 AM
gary c's Avatar
It's only been two months, so what did you decide? You know there is another option, the OE cats is where 80% of the restriction is, replacing them with HFCs (high flow cats) will give you much more growl along with a wee bit of rasp. HFCs will give you around 6 extra whp using the OE exhaust, that's increase you'll feel and hear!
Gary
Old Jul 21, 2015 | 11:31 AM
Gary
I actually haven't made my mind up yet nor have had the time too..but I actually like your ides about hfc's.. any suggestions for what hfc to go with?
Old Aug 30, 2015 | 06:56 PM
G35StrongMan's Avatar
Below is my experience:
1st set Fast Intentions HFC (300 cell metallic), exhaust had a deeper sound and more power through out the entire powerband. Down side only lasted 90K miles untill the welds broke.
2nd set Kinetix HFC, planned on trading the car in so didn't spend the extra money. That was a mistake, the cats were more restrictive and felt they lost power through out the power band. Only plus side, the cats lasted until the my car died a 105K miles later.
2003 G35 5AT coupe setup was a K&N drop in filter, 2006 Airbox for a Manual, Moterdyne 1/2" spacer, and Invidian cat back exhaust.
Old Aug 30, 2015 | 11:32 PM
Gary
Do not, I repeat DO NOT put HFCs on an otherwise stock exhaust. It's is the absolute worst sound I've ever heard come out of these cars. Check it.
Old Aug 31, 2015 | 06:23 AM
I've been sayin that for years. If anything it makes it sound worse
