i NEED EXHAUST EXT. HELP!!!!
Old Mar 1, 2005 | 09:25 PM
sushmaster_g35's Avatar
I NEED HELP! NEED INFO SOON!
i just ordered an invidia exhaust for the 350z, so what would i need to make it fit?
would the 6" ext. pipe from performance nissan work? or would i need a different size?
do you think i muffler shop can make one for cheaper which is just a bolt-on piece?
HELP PLEASE!!!
THANKS!
Old Mar 4, 2005 | 02:14 AM
bump!!
I NEED HELP IMMEDIATELY PLEASE!!!!!!!!!!
Old Mar 4, 2005 | 08:51 AM
waijai's Avatar
i.love.gold
Is this the true dual Invidia?
Old Mar 4, 2005 | 06:20 PM
350Forums's Avatar
why'd you do that? They make a G35 Invidia G200 I sell it all day 889 shipped
Old Mar 4, 2005 | 08:58 PM
RashMan1450's Avatar
WAT 889 shipped. CHECK PM
Old Mar 5, 2005 | 04:21 AM
it is the dual invidia with the two mufflers...different than the g200...
BACK TO TOPIC PLEASE!!!
I NEED THIS INFO SOON!!!!
Old Mar 8, 2005 | 07:26 PM
someone.......PLEASE HELP!!!!!!!!!!!!!!!!!!!
Old Mar 8, 2005 | 07:32 PM
Diesel1's Avatar
Moderator
Without seeing it it is tought to say, but the 6" extension should work if both pipes are of the same diameter. The extension if for the Nismo which probably uses smaller diameter piping. You are probably better off taking the exhaust down to the install shop, have them look under the car and at the new exhaust and then they can determine that. If need be they can make an extensiion piece for probably the same cost or less then the one sold. Or, you can buy the extension piece knowing that you may have to return it (check return policy of the place you buy it from first). If the pice will work, have the shop use that to save time. I think if you do your homework, you should be able to find the diameter of the Nismo exhaust and the diameter of the Invidia you bought.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
