What does Cat-back mean?
Old Apr 21, 2005 | 02:37 PM
WI_Rick's Avatar
I assume it means the catalytic converter is in "back" of something. But, why is that important? My expectation is that it is something to do with increasing the flow. A quick, clear description would be appreciated.
Thanks...
Old Apr 21, 2005 | 03:38 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
I will try to answer this as best I can, but I'm no expert (so take it with a grain of salt).
A lot of cars (mostly Japanese) require a certain amount of back pressure to properly operate. If you don't maintain that back pressure, you can actually LOSE horsepower.
I had a 3000GT in the early 90's and jacked with it too much. I had the remove a lot from the exhaust system. It totally killed the performance.
I'm just assuming that a cat back system has to do something with a system with back pressure.
Again, I may be TOTALLY WRONG.....this is just a stab in the dark.
Old Apr 21, 2005 | 03:44 PM
AmrigFela's Avatar
A Cat-back exhaust (Cat is short for Catalytic converter) means that the exhaust system connects to the catalytic converters and runs all the way to the back of the car. Most exhaust systems are cat-backs since it is illegal to remove your catalytic converters on a street driven car because of pollution.
Old Apr 21, 2005 | 04:16 PM
Pearlcoupeg35's Avatar
Its when the neighbors cat starts hissing and scratching at you, you yell "CAT BACK!" and it backs away!!!
Actually, it means from the catalytic converter back (exhaust)...so if an exhaust is cat-back, it replaces all piping from the Catalytic converter back to the tips...
Right? hahaha
Old Apr 21, 2005 | 04:20 PM
Drewer's Avatar
^^^^^^^^^^^^^^^^ what he said. . .lol.
Old Apr 21, 2005 | 04:53 PM
jnkirk1974's Avatar
So basically.......I was WAYYYYYYYYYYYYYYY OFF!!!
Old Apr 21, 2005 | 06:56 PM
GoSooners's Avatar
In addition, most of the single pipe exhaust systems for our car are actually Y-pipe back because you get a midpipe and muffler section. All true duals sold for our car are true cat-backs.
Old Apr 22, 2005 | 09:28 AM
darnelled's Avatar
What is the performance advantage of an aftermarket Y-pipe vs. a dual exhast ( cat-back) system on a G35 Sedan?
linedr89
Aug 17, 2015 05:11 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
gspot35
Intake & Exhaust
Apr 14, 2004 07:26 PM
epated
Canada
Feb 16, 2004 10:54 AM
skeleton_cru
Intake & Exhaust
Feb 13, 2004 02:02 AM
