NEW! Tanabe Touring Medallion Exhaust
Old May 15, 2006 | 07:36 PM
  #76
njsfastestg's Avatar
G SQUAD
Originally Posted by amg35
sweet looking tip. Any chance you could upload a sound clip? Thanks for your input thus far.
i wish i knew how man, don t have any recording devices i'll see what i can do.
Old May 16, 2006 | 06:12 PM
  #77
Tanabe USA's Avatar
We do have pictures of the G35 Coupe exhaust installed, but the car has a Kenstyle aero kit.
There are additional pics taken by drsifu at the beginning of this thread.
Additionally, these pictures have always been readily available on our website, on the "View Application Chart" section.
http://www.tanabe-usa.com/exhausts/e...tions.asp?id=7
Sound clips for the G35 Coupe are up, albeit sound quality of the clip is very low.
http://www.tanabe-usa.com/soundclips/g35_out.avi
http://www.tanabe-usa.com/soundclips/g35_ind.avi
Old May 16, 2006 | 08:31 PM
  #78
Tanabe USA's Avatar
Just for the G35Driver members:
We made a short video clip of the Medalion Touring on a G35 Sedan
http://www.tanabe-usa.com/soundclips/g35sedan_out.wmv
We used very low tech means to record sound clips, but you can get a basic idea of how the system sounds. The camera we used does not pick up low frequency bass type sounds that well, so end users with this system can probably provide better insight towards how the exhaust actually sounds.
Old May 16, 2006 | 10:45 PM
  #79
G SQUAD
thanks for the help guys
Old May 17, 2006 | 12:51 AM
  #80
graphite6mt's Avatar
any pics of the new heat shield?
Old May 25, 2006 | 08:52 PM
  #81
Tanabe USA's Avatar
The heat shield is integrated onto the muffler canister itself--
On the picture of our 350Z Medalion Touring system, you can see it a bit better:
It's welded onto the muffler canister, and it might not be totally visible, but the company emblem is embossed on the plate.
The shield is purely for aesthetics, to keep the canister from browning.
Old May 27, 2006 | 01:56 PM
  #82
thx for the clear explan. tanabe.
Old May 30, 2006 | 08:13 PM
  #83
Tanabe USA's Avatar
no problem, any questions, please feel free to ask us!
Old May 30, 2006 | 08:26 PM
  #84
amg35's Avatar
Florida G35 Club
Tanabe, are there any dyno numbers available for the sedan exhaust? Thanks.
Old Jun 1, 2006 | 02:38 PM
  #85
Tanabe USA's Avatar
If used as a Y-pipe back exhaust only, the exhaust will only gain approximately 3.5whp and 4ft/lbs of torque.
To really gain significant power on G35's and 350Z's, it's almost mandatory to eliminate the restriction from the factory y-pipe. Since the restriction is further up, any and all exhaust upgrades are negated, and can only reach a certain level of efficiency with such a restrictive piece up front.
We do offer one that made about 7whp when only replacing the y-pipe. With Y-pipe + Exhaust, the gains are much more significant.
This is the front y-pipe:
Old Jun 7, 2006 | 05:23 PM
  #86
jonnVQuest's Avatar
i installed this on my sedan an i Love IT. sorry i dont have pix right now, maybe in a couple days. i found some clips of the exhaust on tanabes website.
here:
http://www.tanabe-usa.com/soundclips/g35sedan_in.wmv
Old Jun 8, 2006 | 01:50 AM
  #87
OH6 G35's Avatar
The exhaust looks really great ! Quality of material and workmanship are excellent (and the welds look great too) ! Also, the tips look like a work-of-art ! Now that I am close to getting hooked, here are some questions. With the packing used (and since it is not stainless mesh), how long will it last before the muffler has to be changed ? Are the Y-pipe and Exhaust System 50-state emission legal ? Great Work !!!
Old Jun 8, 2006 | 06:54 PM
  #88
Tanabe USA's Avatar
The packing material used is a new type of composite material that far exceeds the durability of older conventional fiberglass materials. Fiberglass tends to burn off quickly, and your typical fiberglass pack muffler (or fiberglass cube) will only last about 5 years with regular use.
The new material is called Advantex®, which has much higher durability against heat and chemical corrosion. According to the material testing by the manufacturer, Owens Corning, the material lasts many times longer than older materials.
The Y-Pipe and exhaust system do not modify emissions, so they are emissions compliant-- if the car passes from the factory, it will pass with the exhaust system installed.
Old Jun 8, 2006 | 07:09 PM
  #89
mikesj's Avatar
Hi Tanabe,
I bought your y-pipe. While waiting for shipping, i want to order a cone reducer(from 70mm? --> 62mm).
I already measure my midpipe(about 62 mm outside diameter). I know your y-pipe
is 70mm, but is it inside or outside diameter? and you know what is your dimaeter hole at the flange?
thanks
Mike
Old Jun 8, 2006 | 09:06 PM
  #90
tomcatm's Avatar
With the Y pipe this thing is more expensive than the HKS Hi-Po Ti true dual!?
