Which Y-Pipe is the best?
Old Jun 21, 2005 | 10:56 PM
  #31
LEK's Avatar
LEK
That Guy
Originally Posted by shooter
i thought they all are direct bolt-ons...............
Actually can someone confirm this? I know for sure the UT Y-pipe is direct bolt on but some of the other y pipes need to be welded ex.: Fujitsbo?
Old Jun 22, 2005 | 05:31 PM
  #32
Macgyver's Avatar
To my knowledge, all the discussed Y-pipes are bolt-on to the stock exhaust, meaning the bolt holes in the flanges line up. However, many of the Y-pipe designs (Fuji is one of them) have a larger output diameter than the OEM, as they are generally intended to be mated to an aftermarket exhaust of equally increased diameter. The concern is not that the mis-match would leak, but rather offset to an extent the flow improvement obtained by the smoother bends and 2-to-1 design of the Y-pipe. The sudden reduction in pipe cross-section entering the mid-pipe has an adverse effect at any flow rate. How significant? Well, given the minor gains to be had from a Y-pipe, why give any back? What some have done to avoid this while retaining the OEM exhaust is to add a reducer cone to the beginning of the mid-pipe. In order to do this, the mid-pipe must be cut and the reducer cone with new flange is welded in place making the Y-pipe still a bolt-on. If you have no future plans on an exhaust upgrade, I suggest an OEM matching diameter.
Old Jun 22, 2005 | 05:42 PM
  #33
Infinite1's Avatar
20 Year Member
Very good advice Mac! I always thought it was a plug and play type deal where not much thought it put into it
Danielek
May 1, 2022 01:28 PM
Video Share
Jan 31, 2017 04:00 PM
Moskvitch
Sep 14, 2015 10:15 AM
kevintandmd
Sep 3, 2015 06:41 PM
