350z pipe and stillen filter question
Old Aug 10, 2003 | 08:21 PM
YngPhllyKd's Avatar
what up G's, I was wondering if i could possibly put in a 350Z pipe and a K&N cone filter or a Stillen Cone (like the one that you can get with the stillen airbox) on it instead of getting the whole box. I think that i could get more HP if i dont use the box. What do you guys think? is it possible? Please get back to me. Thanks!
Khal - 2003.5 Sedan: Desert Platinum/Black leather, K&N filter, tints, clear corners, yellow fog lights, etc.
Old Aug 10, 2003 | 08:54 PM
rstark's Avatar
Re: 350z pipe and stillen filter question
If you don't use the box, your intake would be sucking in hot air from the engine which would result in less power.
<font color=blue>-Rick
'03 G35C 6MT Ivory Pearl</font color=blue>
Old Aug 10, 2003 | 11:10 PM
YngPhllyKd's Avatar
well can i use the stock airbox we have and just get the filter?
Old Aug 10, 2003 | 11:32 PM
rstark's Avatar
Honestly, I don't know if you can attach a filter to the stock intake tube *AND* use the stock box. Hopefully someone else will be able to answer your question.
Old Aug 11, 2003 | 08:26 AM
Tfasano's Avatar
The Stillen Hi flo box does three things. It acts as a connector from the pipe to the cone filter. It acts as a shield from the engines hot air, and it draws fresh air from under the car and across the hood using the stock dams. I would not suggest using just a cone filter without the air box. Why would you want to do this? Either go with the stock box and the K&N drop in, or get the Stillen Hi flo. From what I have read, you cant go wrong with either one.
Luv My G
Old Aug 11, 2003 | 11:05 AM
YngPhllyKd's Avatar
well is it possible for me to use the stock box and add the stillen cone?
Old Aug 11, 2003 | 10:43 PM
1crazmofo's Avatar
Check out a JWT POP-Charger with the Z pipe and heat shield... Have one on my coupe and it works and sounds great...Lower air duct on the coupe sits right below the P/C
Old Aug 11, 2003 | 11:27 PM
mbarrad's Avatar
I have the Z-Pipe and the Stillen setup. I am very happy with the application. 200% better than the stock setup. Best designed and well thought out intake so far. I thought about getting the K&N setup, but they are taking their sweet time producing their CAI (and losing profits to competitors at the same time). From the looks of the K&N, their heat shield is lacking. Also not into polished aluminum or chrome under the hood.
Old Aug 12, 2003 | 12:13 AM
YngPhllyKd's Avatar
true true...thanks for the help!!
Khal
derres
Aug 28, 2015 03:27 PM
yassy
Aug 11, 2015 09:31 PM
Team STILLEN
Aug 10, 2015 08:17 PM
wuppiedog
Aug 7, 2015 11:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
