View Poll Results: Which Intake? Before voting please read my post below.
Z-tube and K&N Drop in filter
26
33.33%
Z-tube and Stillen Cold Air Intake
24
30.77%
Z-tube and JWT Pop Charger
28
35.90%
Voters: 78. You may not vote on this poll
Intake? Which one, why?
Old Feb 22, 2006 | 11:15 AM
Triji's Avatar
Originally Posted by KccBaby
Ya, was wondering when I kept reading, what's a power duct? Any pic's to show how to take it off? Ooh, is it a DIY item?
Isn't the power duct the piece that sits ontop of the front grille in front of the air filter...It's that lil rubber peice that directs air into the filter...
I have the K&N Typhoon CAI and I love it...
Old Feb 22, 2006 | 11:52 AM
Jaycee3.5's Avatar
Go with the stillen and Ztube, stillen because of the heat shield/box. when I first installed my stillen it wasnt too loud and didnt roar like others had stated it did make a cool hissing sound when WOT.
I also didnt feel any gains but once i added my ztube it reaaly opened things up and now i can finally say it roars and i feel a slight kick in the upper rev range.
This is the setup to go with aliitle pricey but def worth it !
Old Feb 22, 2006 | 12:01 PM
jaspergtr's Avatar
are you sure that's not a leak hissing?
Old Feb 22, 2006 | 12:53 PM
JGixxer's Avatar
How does your coupe run with the pop charger and Z tube? Noticebly different sound?
Old Feb 22, 2006 | 02:46 PM
JGixxer's Avatar
I'm thinking about installing a Stillen z-tube and a k&n filter (putting the k&n filter in the stock air box) Any sound improvements?
Thanks
Old Mar 30, 2012 | 01:23 AM
mark4healing's Avatar
Anyone familiarized with BLITZ advance power filter? is there a review for this?... has anyone installed it in their G? I'll appreciate some feedback
Old Apr 2, 2012 | 05:05 PM
mpugeda's Avatar
^ like I told you in the pointless thread you CREATED to ask this question...S-E-A-R-C-H . You will learn so much more than someone giving you a quick answer. You'll discover other options, the pros the cons, opinions on sound, maintenance etc. You could have answered your own question by now..stop spamming the threads.
Old Apr 8, 2012 | 10:40 PM
gary c's Avatar
The Z-Tube and K&N drop in filter is the easiest way to go and would probably work well enough for some members. However the Stillen CAI including his Z-Tube has that giant K&N cone filter which flows much more air then the small panel drop in....always my choice!
Gary
Old Apr 9, 2012 | 02:07 PM
06RedG35's Avatar
I have an 06 automatic g35 coupe stock everything. Im only 17 so I can't afford to pay over like 400 for an intake or exhaust system. But my goal is to make my g more loud and hissier as in sporty. It's too quiet for me as a stock. So I'm getting a Z tube forsure but I hear I have to buy 2 intakes?? Is this true? Also what else do I need to buy besides the z tube, thanks
Old Apr 9, 2012 | 02:12 PM
Tollboothwilley's Avatar
Z tube + STILLEN box + JWT filter / velocity stack
Old Apr 9, 2012 | 02:25 PM
mpugeda's Avatar
Two intakes are only necessary for the HR platform. You have a DE, you only need 1. If you're on a budget, install your Z-tube and remove the power duct on the stock airbox to achieve a little bit more induction sound. No it doesn't gain you HP and keep in mind that the power duct probably helps seal off additional heat.
Old Apr 9, 2012 | 02:37 PM
06RedG35's Avatar
Ok I can spend like 300 so I can buy a z tube and instead of removing the power duct, what else could I buy from up there^? A pop charger or a kn filter?
Old Apr 9, 2012 | 05:23 PM
mpugeda's Avatar
Do you want performance? Or sound?
Fyi, you can have a Z-tube and still remove the power duct if you're looking for more induction noise on a budget (you also get to retain the stock airbox which flows more than enough air for your N/A car)...it takes all but 20 seconds to pop off the screws and remove it, no tools needed.
K&N + Z-tube is about 150 bucks. I use Apexi + Z-tube. If you're not worried about heat soak, pop-charger can be had for under $300 I think. (I've never looked it up cause I've never wanted one)
Old Apr 9, 2012 | 05:31 PM
Jairen's Avatar
Here's a Stillen intake for sale. Grab it before it's sold.
https://g35driver.com/forums/engine-...en-intake.html
Old Apr 9, 2012 | 05:32 PM
  #30
bluedevils95's Avatar
I hear the stillen is pretty good
