View Poll Results: Which Intake? Before voting please read my post below.
Z-tube and K&N Drop in filter
26
33.33%
Z-tube and Stillen Cold Air Intake
24
30.77%
Z-tube and JWT Pop Charger
28
35.90%
Voters: 78. You may not vote on this poll
Intake? Which one, why?
Old Apr 9, 2012 | 10:50 PM
  #46
06RedG35's Avatar
Ok thanks guys. I will remove the power duct and buy an Hfc system. So total estimate? Around 350-4?
Old Apr 9, 2012 | 10:58 PM
  #47
mpugeda's Avatar
It depends on which company you go with and don't forget to factor in labor unless you do the install yourself. There's also motordyne art pipes which make good gains for our cars. If I were you I would do more research to avoid making a costly mistake.
  #48
Beebo's Avatar
see if you can find a use set of high flow cats in the marketplace here on the forum
Old Apr 9, 2012 | 11:39 PM
  #49
bluedevils95's Avatar
Have you decided on which one?
Old Apr 10, 2012 | 04:05 AM
  #50
06RedG35's Avatar
Whic hfc's? No I have no idea which which to go with
  #51
06RedG35's Avatar
What brand?
Old Apr 10, 2012 | 04:06 AM
  #52
06RedG35's Avatar
I'm just going to get a hfc and remove the power duct
Old Apr 10, 2012 | 06:49 AM
  #53
Jairen's Avatar
Forget HFC's and get Motordyne ART pipes.
Old Apr 10, 2012 | 10:01 AM
  #54
mpugeda's Avatar
^+1. Remember though, he only has 3-400 to play with + installation.
Old Apr 10, 2012 | 12:23 PM
  #55
06RedG35's Avatar
How much does installation run around? And I can Remove the power duct myself right?
Old Apr 10, 2012 | 12:50 PM
  #56
mpugeda's Avatar
Dam homie, you're beating a dead horse with this power duct.
Walk out to your car, pop the hood, look at your airbox, you'll see the power duct, it's even labeled.. It literally requires popping out two pins and you're done. Removing/installing it isn't a big deal.
Linking you to threads means the info is out there. Dig a little deeper when searching and you will learn a lot more than asking questions that can be answered with a yes or no. Since it seems like you know nothing about replacing your stock cats, READ up on other people's experiences. This will help you decide which brand you want, if you can afford it, or if you even want to replace your stock cats at all. Tons of things to consider..rigidity of HFC internals, rasp/noise from hfc/test pipes, emissions in your state.....added smell...etc.. Check out the exhaust threads, there's a plethora of info.
As for installation, call your local shops and get a quote to see how much they will charge you to replace your cats. Or, scope out the DIY threads if you wanna save some cash.
Old Apr 10, 2012 | 01:09 PM
  #57
Beebo's Avatar
06RedG35
buy this:
https://g35driver.com/forums/nationa...tem-cheap.html
^link^
its a $1,500 exhaust for $300 + shipping... jump on it...
here is what the exhaust sounds like...
Old Apr 10, 2012 | 01:12 PM
  #58
Art is pretty good from what i hear.
Old Apr 10, 2012 | 05:29 PM
  #59
06RedG35's Avatar
06RedG35
buy this:
^link^
http://www.youtube.com/watch?v=SV6OC9qRClo
Should I buy these or high flow cats?
  #60
06RedG35's Avatar
I just removed my power duct and notice a slight difference
