View Poll Results: Which Intake? Before voting please read my post below.
Z-tube and K&N Drop in filter
26
33.33%
Z-tube and Stillen Cold Air Intake
24
30.77%
Z-tube and JWT Pop Charger
28
35.90%
Voters: 78. You may not vote on this poll
Intake? Which one, why?
Do you want performance? Or sound?
Fyi, you can have a Z-tube and still remove the power duct if you're looking for more induction noise on a budget (you also get to retain the stock airbox which flows more than enough air for your N/A car)...it takes all but 20 seconds to pop off the screws and remove it, no tools needed.
K&N + Z-tube is about 150 bucks. I use Apexi + Z-tube. If you're not worried about heat soak, pop-charger can be had for under $300 I think. (I've never looked it up cause I've never wanted one)
Here's a Stillen intake for sale. Grab it before it's sold.
https://g35driver.com/forums/engine-...en-intake.html
I heard on another forum that adding a z tube amd intake does not really affect normal operation, like you can't really hear it until your in a wider throttle range. This true? I mean I want something that makes it louder on start up of engine and overall acceleration and overall drive.
read this: https://g35driver.com/forums/reviews...atalogged.html
listen to this: https://g35driver.com/forums/intake-...eo-inside.html
If that sound is what you are after go for it. It doesn't hurt anything. You'll probably see an increase of 8-10 degrees at a short stop. Again, do you want performance or sound? It seems like you are going in the direction of sound, if that's the case and insist on an intake, almost any aftermarket intake will give you a deeper growl. Just find one you can afford.
this thread gave me all the info I needed to make my decision: https://g35driver.com/forums/intake-...s-results.html
I stuck to the rev-up airbox + apexi air filter (my full exhaust drowns out any induction noise anyway). But if I had to choose an intake my first choice would be Stillen because of their design. Second choice R2C simply out of curiosity.
If it were my $300, I'd put it towards a Motordyne 5/16 spacer (if you're an AT). If MT you need the 5/16+MREV2 combo but this will exceed your budget
So if I'm looking for an exhaust mod how much am I lookin at regarding price and a few names?
I stuck to the rev-up airbox + apexi air filter (my full exhaust drowns out any induction noise anyway). But if I had to choose an intake my first choice would be Stillen because of their design. Second choice Weapon R.
Crawford
Fast Intentions
Kinetix
Berk
do some research for price and what they sound like
here is a vid of Kinetix High Flow Cats (HFC) with a stock 350z exhaust same stock exhaust as the G35 Coupe
just add some high flow cats to your stock exhaust to make it louder.
Crawford
Fast Intentions
Kinetix
Berk
http://www.youtube.com/watch?v=hohxRr0j_hc
Crawford
Fast Intentions
Kinetix
Berk
just the HFC and new gaskets from Infiniti
A very cheap exhaust mod to get you some more grunt to your exhaust would be getting an aftermarket y-pipe from Megan racing. It should only be around $200 and is a direct bolt on so installation should be easy. Downside with the test pipes is that people have told me they will create a lot of rasp and the exhaust fumes apparently smell pretty bad . The other cheaper mod would be getting a nice set of High Flow Cats from Berk technology to name one. And will probably cost you around $3-500 and can give you a little extra torque and HP. Also same story with installation, just bolts right on.
The power duct is part of the intake system so it is in the engine bay. And once you get the mods done, start her up and see how you like the sound. Then you can figure out if you are cool with that or want some more noise coming from the backend.
So I should just remove the power duct before I buy the HFC's and see how I like the sound?
removing the power duct wont change the sound of the exhaust
With the power duct mod, you should only hear a difference when you open up the throttle just as if you had installed an aftermarket intake system. At idle and normal driving conditions staying within 3-4k RPM you won't hear much of a difference with just the air duct and z-tube. The HFC will be the one that makes the overall tone of your car different.
