MD 5/16 Spacer
Old Feb 23, 2006 | 07:50 PM
  #31
ryanwiggum's Avatar
anyone notice an increase in gas mileage with the 5/16 spacer?
Old Feb 23, 2006 | 09:34 PM
  #32
CarFanatic56's Avatar
Originally Posted by jameyb
Spacer arrived today! I will be installing tonight and will snap a few pics of the install.
update?
Old Feb 23, 2006 | 09:38 PM
  #33
jameyb's Avatar
I installed the Modtordyne 5/16" spacer last night (no iso just the basic spacer). The install was fairly easy, however, I must admit I did find myself thinking "why in the heck am I taking apart a perfectly good $35k car."
The spacer itself looks to be very high quality. The hardware came in nice labeled ziploc bags. This along with the detailed instructions ensured there were no problems knowing which bolts went where. Below are some pics. The first is the spacer, the second is right before final bolt down, and the last is the plenum after install.
Driving around today, I definitely noticed better acceleration. I really didn't notice a whole lot of difference at WOT. The major difference was noticed at about half throttle. My G has suddenly found a lot more pep in this range and it seems like it can now decide to downshift faster.
One other thing I noticed and can't seem to figure out is that my car is running cooler per my temp gauge. My temp gauge always rested right in the middle up until last night. Today, no matter how hard I drove it, the gauge never got to center. Anyone have any explanation?
Overall I would rate this as a great mod. I wish I would have dynoed before and after but I felt the spacer didn't need the justification due to the fact that many other dynos, the Sport Z article, etc had already proven its worth. In hindsight, however, I wish I knew exactly how much I gained on my car. Get one if you haven't already. Tony@Motordyne was great!
Next up - exhaust.
Attached Thumbnails MD 5/16 Spacer-spacer-small-.jpg   MD 5/16 Spacer-plenum-open-w-spacer-small-.jpg   MD 5/16 Spacer-plenum-after-small-.jpg
Old Feb 23, 2006 | 09:50 PM
  #34
Strtsk8r321's Avatar
Would appreciate to borrow the torque wrench from the guy in Murrieta! Has anyone had to retorque the screws more then once or twice? Is it going to be a pain in the future?
Old Feb 24, 2006 | 02:26 AM
  #35
05g35mt's Avatar
Hey no problem man. Just pm me your number and will work something out.
Also, I just did a retorque for the third time, just to make sure nothing is loose. All bolts in the middle stayed the same. I had it at 70in/lbs the second time.
But...For some reason I wanted to see if the outside bolts were fine, I found 4 bolts need 1/4 turns @ 100in/lbs. Maybe the dealer didn't torque them right. But no problem. I might just have to check them all of them a 4th time. I am glad I didn't return the wrench.
Old Feb 24, 2006 | 02:55 AM
  #36
with the 5/16th, does the car get any louder since more air is now coming in?...jus wondering
Old Feb 24, 2006 | 03:21 AM
  #37
2 up^ Thanks a lot. I havent gotten the spacer yet tho. Probably soon, tho.
1 up^ I have read many threads saying it is louder.
Old Feb 24, 2006 | 09:12 AM
  #38
jameyb's Avatar
Based on one day of driving the car and putting about 75 miles on it, I would have to say there is no material change to the sound of my car. I can tell it is a little different (slightly deeper maybe) but definitely no change in volume.
Old Feb 24, 2006 | 01:23 PM
  #39
jimmyc13's Avatar
Really? Mine was VERY noticeable.... Have you given it WOT?
Old Feb 24, 2006 | 03:32 PM
  #40
jameyb's Avatar
Yes, quite a few times. This may be another area where the '05s do not get as much sound benefit from mods as the 03-04s, I don't know. I have read on this forum about this same phenomenon with the z-tube, intakes options, and the coupe midpipe.
As I said above, it sounds different (deeper maybe), but for sure not significantly louder. I wish it was, I would have no problems with some volume gain.
Old Feb 24, 2006 | 03:33 PM
  #41
did you put back on the engine cover or leaving it off?
Old Feb 24, 2006 | 03:56 PM
  #42
jameyb's Avatar
Yesterday while driving around it was off, today it is back on. No change in sound either way. Has everyone experienced a significant change in sound?
Old Feb 24, 2006 | 04:36 PM
  #43
FenixL1P's Avatar
you guys are making me more jealous and envious every minute and i'm usually very patient....ordered mine (full mrev+ isothermal kit) last week along with stillen sway bars but everythingg35 haven't recieved their stock yet so gotta wait till next week... i did save nearly $15 on shipping and $70 on taxes though... i couldn't believe the sway bars only showed up as 12lb shipping weight.... i think the stock front swaybar weighs that much or more alone....
Old Feb 24, 2006 | 06:22 PM
  #44
g6g35's Avatar
i havent really noticed a louder sound in the engine either
Old Feb 24, 2006 | 06:25 PM
  #45
jameyb's Avatar
If you are getting the MREV for your revup engine, don't be jealous of us.
Good luck with the waiting, I know it sucks.
