Where to buy antifoulers to get rid of CEL?
Old Apr 30, 2006 | 02:15 PM
Serengettisandg's Avatar
Hey guys,
Just installed my Strup Test pipes and got a CEL, could you please let me know where to pick up anitfoulers and also post a picture if anyone has some. I don't know what they look like. Thanks.
Old May 1, 2006 | 01:24 AM
RebelinRI's Avatar
I heard of a cheapo easy fix. All you need is a couple a washers when installing the o2 sensors. It pulls them back enough to get a false reading and then you should be able to clear the light. Hope it helps.
Old May 1, 2006 | 01:27 AM
BadCommand's Avatar
http://www.o2sensorsimulator.com/?OV...OVMTC=standard
Old May 1, 2006 | 05:29 AM
GReddySetGO's Avatar
You can get the parts at Auto Zone, I forgot the part numbers though. You need 2 sets (4 total). Both should run you about $10-12 total. If you do a search I think you might be able to find the part numbers. I know its been posted.
Old May 1, 2006 | 07:08 AM
Audible Mayhem's Avatar
look for the Help brand 42009
you will need four of them. you drill a hole in two of them about a half inch. this is so the O2 sensor can screw into the one with the hole in it, then that (o2 sensor and first non fouler) screws into the second non fouler. this is easy to see what i mean when you are holding them in your hand. then you screw the whole set up into the bung where the o2 sensor was originally. all you are doing is moving the o2 sensor outta the pipe so it doesnt pick up as much exhaust fumes and throwing a code
good luck!!
Old May 1, 2006 | 10:20 AM
ISMSOLUTIONS's Avatar
I used the HELP 42002 not the 09...but heard there are 2 numbers....Rick
Old May 1, 2006 | 03:18 PM
Maybe its 42002 & 42009. There are 2 part numbers. You use 2 non-foulers for each side, total of 4.
Old May 1, 2006 | 09:40 PM
Thanks guys!
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
Albanian122
Sep 7, 2015 07:41 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
