Kenstyle rear and what i see through holes
Old Jun 18, 2006 | 12:42 PM
2FastG354U's Avatar
I doubt it but post some pics man!
Old Jun 18, 2006 | 12:50 PM
gary c's Avatar
Kenstyle rear......holes......?
How may we help you if we can't see what your talking about? Maybe you only see the holes when
you lean over............haha. Post pictures!!
Old Jun 18, 2006 | 12:58 PM
x7original4x's Avatar
not supposed to be like that......i believe....
Old Jun 18, 2006 | 01:06 PM
G35SHAWN's Avatar
Just paint the metal bar black, & then install mesh, problem solved.
Old Jun 18, 2006 | 01:07 PM
ON's Avatar
ON
that's why you're suppose to put a black mesh over it. I believe that is a support bar or something...just in case someone rear ends you, you know? :P i'd leave it on and cover it with a mesh...that's what everyone does.
Old Jun 18, 2006 | 01:12 PM
gary c's Avatar
You do have holes..................!
Yea, that looks like the rear brace to keep someone
from hitting your gastank upon impact. Easy fix,
mask off the area around the brace like 3 feet. Spray
flat black and it will disapear. Or you could mark off
the area that shows thru your new bumper, remove
the bumper and cut the area that shows with a plasma cutter then reinstall the bumper. I vote for
paint myself!
Old Jun 18, 2006 | 01:28 PM
G352NV's Avatar
Never enough
Yep paint it black.
Old Jun 18, 2006 | 02:49 PM
dubs's Avatar
two options:
-paint the brace black & install mesh on the bumper
-install CF inserts behind those openings in the bumper & seal it up.
I did option one on my KS rear bumper
Old Jun 19, 2006 | 01:04 AM
Rookie84's Avatar
Mine is painted black I believe or mesh from customautomesh.com is hiding the bar really well. I am using 1/8" mesh.
Old Jun 19, 2006 | 01:28 AM
caskyline's Avatar
Former Vendor
The metal bar is the actual bumber.Best thing to do is remove the bumper cover,paint the bumper and add some mesh to the cut out areas.
Old Jun 19, 2006 | 02:04 AM
truplay8's Avatar
THE BATMOBILE
grab some mesh or paint it black
Old Jun 19, 2006 | 03:50 AM
iChiBahN's Avatar
I agree with the painting it black n meshing it idea
rezendvous420
May 31, 2020 01:26 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
