Removing the Emblem?
Old Jun 20, 2006 | 12:44 PM
35Blaze's Avatar
Does anybody have any good ways of removing the rear infiniti emblem cleanly so it doesnt leave any sticky **** on the car? Any ideas would be appreciated.
Old Jun 20, 2006 | 12:51 PM
1stG35inCTRY's Avatar
I used a little heat... then i scrubed it with my VISA and the glue thing I removed with my D&G perfume
Old Jun 20, 2006 | 01:10 PM
KenK2's Avatar
The Pole
I took off the 'G35' last night and this is what I used..
Dental floss
Goof Off,,, for the sticky stuff did it 3 times
Wash mitt with dawn after each goof off application
Meguiars NXT paste too get rid of the haze from the goof off
Go slow and you should be ok
Old Jun 20, 2006 | 01:19 PM
PoliPino's Avatar
I used a hairdryer to heat up the adhesive to make the emblem easier to remove. Then used Bug & Tar remover to remove the excess adhesive. Worked out real well for me.
Old Jun 20, 2006 | 01:26 PM
03silver's Avatar
I rubbed most the gunk off with my fingers, then NXT wax to clean it up.
Old Jun 20, 2006 | 01:57 PM
35Blaze's Avatar
Someone told me that Nail Polish remover will work for the sticky stuff? Anyone else heard of this?
Old Jun 20, 2006 | 07:08 PM
SKYY-35's Avatar
that's iffy.. that acetone is pretty strong. Goo gone works great. I used a lil 70% isopropyl alcohol as well.
Old Jun 21, 2006 | 02:37 AM
truplay8's Avatar
THE BATMOBILE
search for a DIY.........heat it up........take off with floss......wax
Old Jun 21, 2006 | 02:42 AM
sf887's Avatar
http://smut101.com/debadging/debadging101.htm
check out that link, it shows how to debadge an altima, but same exact process since the altima has glue holding the emblems just like the g, or any other infiniti/nissan
Old Jun 21, 2006 | 02:41 PM
35Blaze's Avatar
Thanks for the input.
Old Jun 21, 2006 | 03:02 PM
OCGsedan's Avatar
wow - i can't believe no one turned the flames on high w/ the ever-so-popular "DO A SEARCH" ..
PS - DO NOT use nail polish remover.. that will eat right through your clear coat.
Old Jun 21, 2006 | 03:05 PM
Bigd2k6's Avatar
Do A Search!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! Lol ^
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
