Seibon Hood HELP
Old Oct 24, 2006 | 01:58 AM
G35SHAWN's Avatar
Seibon Hood HELP (problem solved)
Allright guys, for last two hours i am trying to install my seibon Ts hood however the damn hood is not closing at all, is there any special way to put this thing, perhaps adjust the hinges? Please help me out here at this point i am totally frustrated
Old Oct 24, 2006 | 02:10 AM
Calvin's Avatar
Overglorified Altima
im waiting for bobshuai to chime in on this. i just PMed him..he deals with seibon hoods all the time..(great seller/great prices for seibon oem/ts/js hoods too)
Old Oct 24, 2006 | 02:12 AM
G35SHAWN's Avatar
I really need some help asap....
bobshuai's Avatar
okay you just need a ratchet to loosing the bolt on where factory's locking adivse is, then move the locking plate down a little bit then tighten it. then you are set, you don't need to touch your hinges. No need and don't mess with the hinges near the windsheild. you got problme then pm me.
air ratchet will be even more eiser otherwise muscle need it.
Old Oct 24, 2006 | 02:23 AM
bobshuai's Avatar
i hope you don't have any crazy stuffs in side the engine bay to stop it close. I only have CAI and not thing else.
Old Oct 24, 2006 | 02:24 AM
G35SHAWN's Avatar
Crewford plenum & hks intake...
Old Oct 24, 2006 | 02:28 AM
bobshuai's Avatar
should be fine, try it. i hope that helps you. just hope isn't your plenum's issue. if is your plenum's issue then do the opposite, raise up the locking plate a bit until you can lock it then as long as you can lock your hood first then go buy a pair hood pins. keep me update.
Old Oct 24, 2006 | 02:44 AM
G35SHAWN's Avatar
I am very sure it's not the plenum, cause i have seen others with this same hood with plenum & didn't had any problem, plus i checked the clearence already & it's the stupid factory locking that causing all the drama....
Old Oct 24, 2006 | 03:00 AM
G35SHAWN's Avatar
bump
Old Oct 24, 2006 | 03:04 AM
bobshuai's Avatar
can you give me not to far away shot with locking plate. if that is possible. i really can't see it with that close.
Old Oct 24, 2006 | 03:16 AM
bobshuai's Avatar
did you move up and down with the locking plate?
Old Oct 24, 2006 | 03:22 AM
G352NV's Avatar
Never enough
I had to cut a hood latch off another hood. Then cut the seibon one off and weld the other on to make it longer.
Old Oct 24, 2006 | 03:29 AM
bobshuai's Avatar
hood
This is my hood on my car, you can see that space is very tiny. I moved the locking plate down about 1/4" at the time until i am happy with the space.
Old Oct 24, 2006 | 04:27 AM
GReddySetGO's Avatar
I didn't have any problems with mine. I just push down with two hands and it locks.
Old Oct 24, 2006 | 04:33 AM
Mine had no gaps on the stock grill, and a small one on the SP grill.
