Front Bumper Removal
Old Jun 27, 2007 | 02:51 PM
xjohnnyleex's Avatar
Does anybody have a DIY or instructions on how to remove the front bumper and install the customautomesh.com mesh? Thanks
Old Jun 27, 2007 | 03:05 PM
imalazeeass's Avatar
look up triji, he has a DIY on installing headlights, which shows u how to remove the bumper.
Old Jun 27, 2007 | 03:09 PM
Calvin's Avatar
Overglorified Altima
to remove the bumper (mostly)
https://g35driver.com/forums/body-interior-exterior-lighting-diy/125363-diy-headlight-housing-removal.html
dremel the stock mesh out. install the customautomesh hardware that you should have bought. slap in the mesh. boom, youre done.
Old Jun 27, 2007 | 03:14 PM
Gam3's Avatar
so no jack required?
Old Jun 27, 2007 | 03:25 PM
Calvin's Avatar
nope.
Old Jun 28, 2007 | 12:58 AM
sfgr415's Avatar
Make sure to put towels over your bumper edges (where they meet the fender). If not, you will scratch up your fenders.
Old Jun 28, 2007 | 06:14 PM
Thanks for the answers!
Old Jun 28, 2007 | 06:29 PM
savefatkids's Avatar
STOPPP..dont do it.. i put the custom auto mesh on my old stock bumper and the only benefit was that i had a $hit load of bugs and leafs in my lower grills!
Old Jul 15, 2007 | 08:49 PM
Jining's Avatar
... my bumper would not come off and I followed the instructions exactly! FACK!!!
Old Jul 15, 2007 | 09:53 PM
Triji's Avatar
Here is the DIY for the headlights, take a look at it... The only thing you need to do different for removing the whole bumper is to use a 10mm rachet to remove the bolts right under the front bumper that holds the plastic engine undercover on.
You can also use a 10mm rachet if you have a long enough extension on the rachet to get the 4 bolts (2 on each side) that hold the fender to the bumper on the sides instead of the long phillips.
https://g35driver.com/forums/showthread.php?t=125363
I hope this helps you
Jining... Where did you get stuck at?.... Bumper should come right off... takes very little time to do...
Old Jul 15, 2007 | 09:58 PM
Jining's Avatar
well i did use a phillips to remove the 2 on each side in the wheel wells and each side of the bumper would nearly come off but it seemed as the bumper was still bolted onto something. and yes I took out the 2 plastic clips as well :0/
Old Jul 15, 2007 | 10:05 PM
suicidesam's Avatar
****defected****
no ****!!! i have that same issue
Old Jul 15, 2007 | 10:12 PM
Triji's Avatar
Did you take out the pop rivits along the top of the grille? There are like 6 up there , also did you take the side marker lights out?
Old Jul 15, 2007 | 10:42 PM
Triji's Avatar
oops.... I did not click on the link aHero4Eternity posted up there....
He beat me to it
Tukeeg35
Sep 27, 2015 12:16 AM
derres
Aug 28, 2015 03:27 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
st33zygill
Jul 29, 2015 10:05 PM
