anyway to fix tint on dot matrix?
Old Jan 2, 2008 | 03:47 PM
bngu1's Avatar
i bought my car used and it already had window tints on them. there are alot of bubbles on the rear windshhield where the dot matrix are. i've read dozens of threads regarding to this problem. my question; is there a way i can fix it myself or do i have to retint the windshield? honestly, it doesn't bother me that much but i want it done right.
Old Jan 2, 2008 | 03:54 PM
g35rcr's Avatar
you can try heating it and pressing the tint in but, if it has already dried there is nothing you can do
FlameOn's Avatar
I haven't ran into this problem before. But me personally, I would just pay the extra money and do it over and not worry.
Old Jan 2, 2008 | 04:05 PM
Daddygonz's Avatar
Remove it and replace it with a strip of black vinyl. When they tinted both our G35 coupe and I35 they put black vinyl on the top so it would not bubble. Plus it blocked out alot of sunlight, even though my I35 has the motorize sunshade in the back.
Old Jan 2, 2008 | 07:54 PM
Blue Lion's Avatar
I agree. On both my G and my Corvette, the dots prevented the tint from sticking, and I know the jobs were done right. Some people have this problem, others don't. It shouldn't cost $25 for your tinter to cut the old tint off and put a strip of vinyl on there.
I've heard of people sanding down the dots but it can't be easier than $25 and vinyl.
Old Jan 2, 2008 | 09:40 PM
redlude97's Avatar
IMO, the vinyl option is tacky looking and I would continue to look for a good tinter that can do dot matrix properly like I did.
Old Jan 2, 2008 | 11:04 PM
Beebo's Avatar
^+1
Old Jan 3, 2008 | 07:15 AM
g35rcr's Avatar
any good tint shop can make it stick, i have seen them use glue sticks and you couldnt tell on the car
Old Jan 3, 2008 | 08:14 PM
g35guy86's Avatar
I had that on my car window but once it was in the sun in just eventually evened out on the top by basically unsticking but it looks even now. Had the same issue on my 03' sedan.
Old Jan 3, 2008 | 08:17 PM
O HELLA OEM's Avatar
i have the same problem with my back dot matrix..like i see bubbles and shiet..im gonna have to get my rear re tinted or something..
Old Jan 3, 2008 | 09:21 PM
Polishthrust's Avatar
Here is your solution but it only works with fresh tint so u might have to retint and then even it. But try it on your back window anyway u have nothing to loose.
When i got my tint done i hade bunch of uneven patches, so on the 3rd day i took a credit card and put a SOFT wet cotton cloth over it. Then i dragged it (using both hands and applying even pressure) lengthwise across the dot area from the inside of the car. The goal is to use it as a squeegee and even out all the dots and bubbles. Go though it a few times and it should be fine. Mine looks perfect now.
KruZZe
Feb 27, 2023 05:04 PM
R350k5
Lights
Jan 12, 2016 09:22 AM
BradMD_96
Oct 6, 2015 09:31 AM
TNRocker
Sep 21, 2015 08:36 AM
