Wavy CustomAutoMesh?
Old Feb 10, 2008 | 11:20 AM
jlin615's Avatar
I installed the CustomAutoMesh on my Gialla grille 2 weeks ago, the mesh was put on pretty straight. In the last 2 days, I notice the mesh is getting wavy looking from the side angle. These are vertical waves, I tried straighten it out by gentley pushing on it from the inside, no help. Any of you had this problem?
Old Feb 10, 2008 | 12:54 PM
Boston's Avatar
I had it on my Gialla and didn't have any issues. Remove the grille and try stretching the mesh to remove any slack.
Old Feb 10, 2008 | 02:38 PM
SxExCx's Avatar
+1 on stretching it more
Old Feb 10, 2008 | 02:46 PM
g35rcr's Avatar
did you heat it up with a blow dryer to straighten it?
Calvin's Avatar
Overglorified Altima
take it off. get a hair dryer and heat it up. then stretch it out by pulling on it while it's hot and set it on a flat surface with weight on it to keep it flat.
Old Feb 10, 2008 | 04:53 PM
jlin615's Avatar
I think I'll take off the mesh and heat it up with blow dryer, then pull it straight. Just a pain to remove/reapply the 3m tape, align the holes to install.
Old Feb 10, 2008 | 04:56 PM
Calvin's Avatar
3m tape for what? the grille? you don't even need 3m tape if the grille fits properly.
Old Feb 10, 2008 | 05:14 PM
jlin615's Avatar
Really? The gialle grille came with double-sided tape, I thought you need it for it to be secure on the bottom.
Old Feb 10, 2008 | 05:20 PM
Calvin's Avatar
you don't need it. ditch it.
Old Apr 10, 2008 | 09:13 PM
1illgt350's Avatar
heat up the mesh then stretch it! should do the trick!
Scootch
Dec 28, 2011 08:00 AM
jlin615
Jan 25, 2008 03:37 PM
MM_G3520
Tuner & Dyno
Jan 12, 2008 01:57 AM
Dieselnuts
Dec 12, 2006 08:58 PM
