Someone help this is driving me crazy??!!?!?!?
Old May 8, 2008 | 08:52 PM
DrewTheSuit's Avatar
Just recently i have been experiencing a noise that sounds as if it is coming from under my car...it is an intermitent noise that seems to be more prevalent during lower gears, but happens both while cruising(not giving any gas) and when i gas it; however, doing this will also make it stop occassionally...it sounds like when you put a baseball card in your bike spokes "tttttrrrrrrrrlllllllllllllll" but it has more of a passing air noise than the tick of my baseball card analogy...since i can't get to the dealership anytime soon, i was hoping someone here maybe able to shed some insight??????
Old May 8, 2008 | 10:03 PM
hyperlite21's Avatar
i have the same problem, but it comes and goes.....
Old May 8, 2008 | 10:35 PM
^^^as does mine, but that's what's killing me...if it was constant i think i could get use to it, but i love the exhaust note too much to keep listening to this
Old May 8, 2008 | 11:42 PM
JY35's Avatar
My car does the same thing when it starts but when it warms up kinda reduces in sound
Old May 9, 2008 | 03:04 PM
IvoryGT's Avatar
the clutch chatter?
Old May 9, 2008 | 10:16 PM
^^^i guess it could be the clutch, but any ideas why it has just started with this horrendous noise...btw still running stock clutch and flywheel, in fact i don't have any performance mods that have ever been installed
Old May 9, 2008 | 10:28 PM
its on a 5at
Old May 9, 2008 | 10:52 PM
6mt
Old May 10, 2008 | 10:42 PM
anyone have any other ideas/input???
Old May 13, 2008 | 08:28 PM
Ttt?!?!?!?!?!?!?!?!?!??!??!?!?!?!?!??!?!?!!
Old May 14, 2008 | 01:12 AM
PROVIDER's Avatar
I have the same damn problem. I have an '05 coupe 5AT and comes on when I accelerate. I brought it in, and the tech said he could not confirm it, but it could be a pinging from bad gas. I don't think so. At $4.50/gallon, that s%$@ better not be bad gas. Anyone else have ideas? I'm gonna bring it back in this week to see what they say
Old May 14, 2008 | 02:46 AM
blues's Avatar
found this?
I just found this, I don't know if this is related to your noise.I thought I'd post this and share it..
After more than three years of documented warranty problems, Infiniti finally released a TSB that (1) acknowledges there is a noise problem with the compression rod bushings, and (2) provides a solution for just replacing the defective bushings themselves (the beefy aluminum rods themselves are not the problem, but until now, that was the LRU).
The TSB is: ITB08-013, "NOISE FROM FRONT COMPRESSION ROD"
__________________
Mry
Mar 3, 2023 01:03 AM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
ev_g35
Interior
Aug 14, 2015 02:05 PM
mcneil_g35
Aug 5, 2015 12:03 PM
