Highbeams are out...fogs still on...
Old Mar 2, 2009 | 10:26 PM
BurntRenolds's Avatar
My highbeams are out but I can still turn on my fog lights...shouldn't they both be out (same bulb)...Could this be a fuse problem???
help please...
Old Mar 2, 2009 | 11:30 PM
dofu's Avatar
20 Year Member
Unless you're running DRLs, I think it's odd how the high beams went out before the low beams...
Either way, I'd check the bulbs first. Like stated above, they're dual filament so either can go out at anytime, while the other works fine still.
Old Mar 3, 2009 | 11:29 AM
GR8TG35's Avatar
I lost one of the fog filaments, but the high still worked.
I would guess its the High beam filaments that went.......Did you check your fuses?
Old Mar 3, 2009 | 03:29 PM
no which fuses should I be checking for???
Old Mar 4, 2009 | 07:47 AM
GR8TG35's Avatar
There are a couple locations for the fuse boxes in the G.....One is the drivers side kick panel, but I'm guessing the fuses for the headlights/tail/interior etc. are located behind the battery compartment. In order to get at the fuse box, you need to remove the lower windshield cover moulding (black plastic trim pc) by removing the plastic button type fasteners....That should give you access to the fuse box.
Go outside and look at your car, I think it should make sense.
jeffbdye
Jun 1, 2018 03:51 PM
Jiggerjuice
Dec 6, 2015 10:29 PM
chinee
Aug 8, 2015 10:11 AM
nascarbuff17
Jul 16, 2015 10:23 AM
attarday
Jul 15, 2015 04:03 PM
