Window Motor or Window Regulator?
Old Mar 19, 2009 | 07:13 PM
jerryG45's Avatar
I have been having issues with my window for the past few months.
I dont know what if it is the window motor or regulator.
One day I walked to my car to find it half down, with a curious face I rolled it back up. No issues for several days then I started to see the window having alot of trouble going down and making a bit of a noise.
At times banging on the door can get it back up or down.
then it began needing to be focred down and going up was always easy.
now the window became stuck down. So being frustrated I took the door apart, and motor to clean it due to perhaps all the carbon build up.
no solution, stayed down until i tapped the window and came back up.
Now the window works like the several days it first started to bug out.
Sometimes it will get stuck , but waiting a few minutes usually gets it solved. Going down still has trouble but for the most part does it on its own.
I do not know what the problem is.
Window motor or regulator?
Old Mar 21, 2009 | 01:35 AM
twalls's Avatar
CLUB MODERATOR
I've recently been having issues w/ my window motor too... It seems to be a common problem among 04-05s.. I've searched and found some random info.. I think it's just a problem we're going to have to live w/.. Some people are on their 5th or 6th window motor..
Mine will not go down at all sometimes, and then when I stop and start the car again, it'll work just fine.. Sometimes when I let it back up, it'll go all the way up then down half way when I let the button go.
It's POSSESSED..
Old Mar 25, 2009 | 12:44 PM
jerryG45's Avatar
so my issue is the motor?
Old Mar 25, 2009 | 09:53 PM
twalls's Avatar
CLUB MODERATOR
yupper... that's what I've been reading.. It's the fact that the motor was built w/ no vents for the the carbon fillaments to fall out.. So they cake up the brushes inside the motor.. The only way to truly fix it is to remove the motor, clean it out, regrease it, and then put it back.. But the build up will eventually happen again.. That's all just from researching on here... There's no "real" fix to this that's permanent.. you'll have to continue doing this as Nissan never made a replacement motor for this w/ vents.. Even buying a new one will eventually fill up again..
Old Mar 25, 2009 | 10:04 PM
Vrod-Mike's Avatar
My 05 had the right window motor replaced at 23k.
Old Mar 25, 2009 | 10:05 PM
twalls's Avatar
CLUB MODERATOR
are you the first owner?
Old Mar 25, 2009 | 10:37 PM
Vrod-Mike's Avatar
No I just bought it with 36K, but the original owner bought it from a dealer that is a client of mine so I had them print me out the service history for the car.
Old Mar 25, 2009 | 11:37 PM
twalls's Avatar
CLUB MODERATOR
yeah.. it will eventually happen to yours.. I don't really let my windows down a lot, and it eventually happened to me.. bought mine w/ 24k and by 46k it was doing it.. I believe in AC, not really letting the window down much.. But it got me anyway.. However, mine was never replaced that I know of... Good luck w/ your new one.. It's a pain when it starts acting janky.
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
