Splash Guard Removal?
Old Jun 13, 2009 | 01:13 PM
CLEANBS's Avatar
Is it pretty straight forward?
Are they just screwed on?
I read there might be sticky taped on?
Old Jun 13, 2009 | 01:19 PM
PTownG's Avatar
there's a couple screws on the flat part facing the wheel and sticky tape along the lower part along the body
Old Jun 13, 2009 | 05:27 PM
CLEANBS's Avatar
so its gonna be a messy removal
il see if the dealer will do it for me
Old Jun 13, 2009 | 08:04 PM
pwebb's Avatar
are you talking about the lower pan you would remove if you wanted to change the oil? its easy, just a bunch of 10mm bolts. a power tool will make your life alot easier. corrosion is a bastid!
the fender liner - surrounding the tire - is a bit of a hassle, but still pretty easy. take your time, and dont force anything apart.
Old Jun 14, 2009 | 02:22 AM
CLEANBS's Avatar
im talking about these badboys
http://cgi.ebay.com/ebaymotors/INFIN...Q5fAccessories
Old Jun 14, 2009 | 02:31 AM
G U LATER's Avatar
2 tabs and sticky tape. Once the tabs are off you have to peal the splach guard off, then use goo-gone to take of the tape from your bumper.
Old Jun 14, 2009 | 02:51 AM
COMMANDOE's Avatar
I am doing this myself this weekend. (the rears) looks to be waaaay easy, don't pay for that dude, pay for tough stuff. 2 screws parallel with ground, one bolt on bottom and 2 pieces of tape.
Old Jun 15, 2009 | 11:55 AM
CLEANBS's Avatar
yea im gonna do it tommorow
thanks
Old Jun 16, 2009 | 01:38 PM
kable33's Avatar
Yeah I wanna do this too. But I wasn't sure if some dark dirt and grime outline would be left because the splash guard had been on there for so long. Let us know how it goes and post pics if you can.
Old Jun 16, 2009 | 09:47 PM
COMMANDOE's Avatar
Just did this a breeze, 20min one, 15 min the other.
You need short phillips screwdriver for 2 screws in wheel well, and long 10mm socket for the bolt underneath. (I have flaps already so all holes were pre-existing) Yes there is some adhesive from previous flaps, I scraped it off with a popscicle stick then remaining with alcohol pad. (not worried about scratching since new is covered). There are 2 pieces of double sided tape already attached to new flaps. Take off the cover of unused portion of tape and hold new flap on while screwing everything back in, then voila! Oh yes there is a plastic push tab on the bottom.
Any questions let me know or if need pics but i don't think really necessary pretty easy and straight forward, fits perfect!
Interesting the amount of sand/dirt trapped underneath both.......
Old Jun 18, 2009 | 12:38 PM
CLEANBS's Avatar
i just took off my fronts in like 10 minutes
the rears however, I couldnt get the bolt on the bottom
il try again tommorow
Old Jun 25, 2009 | 10:43 AM
O HELLA OEM's Avatar
so the front splash guards are held on with 2 bolts in front and 1 bolt on the bottom followed by sticky tape
Old Jul 7, 2009 | 01:21 PM
Gspotsilver35's Avatar
going to do this today. those splash guards are hideous
Old Nov 17, 2009 | 06:42 PM
obsdnoblivion's Avatar
How different is this for the sedan? Also, on my 97 maxima on which I installed splash guards, there were these pieces of plastic that were screwed in that I had to remove. They covered up the spot where the splash guard would be if there were no splash guard. Is there such a part for the 04 G35 sedan? Does the car look naked and exposed right where the splash guards should be once you have removed them? Thanks!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
dcsbh1
Oct 1, 2015 03:15 PM
