Spray gun
Old Sep 20, 2009 | 08:32 PM
Project's Avatar
Spray gun
Thinking about picking up a hvlp gun. Anyone recommend a good gun or one they have personally used before. Looking to spend between 100-200 on it and its going to be for personal use not professional. Any input would be appreciated.
Old Sep 21, 2009 | 09:04 AM
idrive_MD's Avatar
Not sure on your local codes, but just about everywhere is switching to water based paints with low VOC. I suggest you look for guns tailored to water-borne paints, they should have an all stainless contruction. Ideally you'd want at least a couple of guns so you dont mix heavy primers with your thin colors and clears, or at least one gun for primer/color and one gun for clears. For personal use though, you can probably get away with one gun. I bought a cheap two gun kit for a little over $200. I suggest checking out harborfrieght or the spray gun depot
Old Sep 21, 2009 | 05:24 PM
IvoryGT's Avatar
yeah habor freight has some cheap ones...The one i have is from finish line and wasn't that cheap. Im picky about the finish and ultimately a good finish depends on the gun as well. SATA guns are the pros choice.
Old Sep 21, 2009 | 08:19 PM
Project's Avatar
awesome thanks for the info
Old Sep 21, 2009 | 08:39 PM
Texasscout's Avatar
You are kidding? Water based auto paint? How does it hold up?
Old Sep 22, 2009 | 08:29 PM
Project's Avatar
damn hippies
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
