OEM rear lip for an 05?
Old Mar 19, 2010 | 09:26 PM
jin22gt's Avatar
Is it possible to put on a OEM 03-04 rear lip on a 2005 sedan? without major work needed?
Old Mar 19, 2010 | 09:37 PM
CandlestickPark's Avatar
ill Sedan
By OEM I assume you mean Nismo, they are discontinued and you will likely not find one. There have been 2 of us that have done it, including myself, another guy is working on it right now.
Parts you will need:
1. An 03-04 rear bumper
2. An 03-04 rear lip (Nismo, Stillen, Wald Replica, etc.)
3. 03-04 mudguards, piece right behind the wheel that goes behind the lip. These should not be confused with splash guards which go on top of the bumper. These will make everything line up with the 03-04 bumper and lip without modification. If you don't purchase these then your body shop will have to do some slight modifications to make everything fit. IIRC they are ~$150 from Riverside Infiniti.
Here is the result:
heyitzalex
CandlestickPark
Old Mar 19, 2010 | 09:38 PM
Beebo's Avatar
CandlestickPark aka Marcus did it. send him a PM
https://g35driver.com/forums/media-s...-rear-lip.html
Old Mar 19, 2010 | 09:39 PM
Beebo's Avatar
you beat me marcus
Old Mar 20, 2010 | 08:52 AM
jin22gt's Avatar
its not possible to put the nismo rear lip on an 05-06 bumper? I would need to get a 03-04 bumper for this?
Old Mar 20, 2010 | 09:34 AM
ill Sedan
^I'm not aware that it has ever been attempted before. The lip would have to be modified by your body shop. The extra labor associated with that is not worth it IMO and you aren't guaranteed OEM fitment. Overall its cheaper (and it will likely fit better) if you get an 03-04 bumper.
Old Mar 20, 2010 | 10:24 AM
jin22gt's Avatar
Does the 03-04 bumper fit perfectly or would i need to do some work done?
Old Mar 30, 2010 | 03:57 PM
boostedforlife's Avatar
looks good,
not trying to thread jack, but wondering where can we find the oem lips? besides used?
Old Mar 30, 2010 | 05:16 PM
ill Sedan
Originally Posted by 2005g35sedanyay
looks good,
You won't be able to find one new anywhere that I'm aware of (and I searched quite a bit before I bought a used one)
ill Sedan
Its a direct fit. You'll need the 03-04 mudguards (part behind the wheel that goes under the lip) for everything to line up properly. If you don't get them your body shop can mod it a bit to fit.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
yoyoyo8
Aug 12, 2015 03:04 AM
T.Y.M1210
Jul 29, 2015 11:53 AM
djreinx
Jul 13, 2015 05:04 PM
