Pic Request - How did you mount your INGS side skirts?
Old Jun 15, 2010 | 02:50 PM
xXHotelCrazyXx's Avatar
Can anyone provide me pictures of the door jam area how the skirts are secure to the car and the hardware you used? Thanks!
Old Jun 15, 2010 | 03:09 PM
cdubel01's Avatar
CLUB MODERATOR
interested to know...
Old Jun 15, 2010 | 08:51 PM
bump
Old Jun 15, 2010 | 08:59 PM
HenryLee's Avatar
I dont know about my INGs but here's a picture of Impuls.
Old Jun 15, 2010 | 09:14 PM
Ya im looking for what kind of hardware was used since aftermarket skirts dont use clips. Thanks for the pic henry
Old Jun 15, 2010 | 10:26 PM
GreenGoblin's Avatar
The goblin resurrection
You can buy clips that fit the oem holes that have a small hole to but a screw in.
Old Jun 15, 2010 | 10:41 PM
where? linkz? pic?
Old Jun 15, 2010 | 11:59 PM
walshtj's Avatar
I think riverside carries them...
Old Jun 16, 2010 | 01:51 AM
Silencer_0's Avatar
Here are my INGS sides.
Picked up some OEM clips from Riverside Infiniti, I believe they were like 80 cents each. Just ask Rick about the clips for sideskirts, he'll know what you mean.
Used #12 x 1" Pan Head Phillips screws for metal, bought from Home Depot, along with 5/16" SAE flat washers. Washers were used to spread the pressure around to prevent cracking the sides. Used some touch-up paint so they won't be too visible.
Oh, and all my LEDS are white, not blue .
Old Jun 16, 2010 | 03:29 AM
You are the man, thanks so much Silencer! Did you use any hardware to secure them on the bottom of the car, i heard with aftermarket skirts you cant do so like the OEM ones are. Did you drill them your self? How easy was it aligning them for drilling? Once again than you so much!
Old Jun 16, 2010 | 03:53 AM
Silencer_0's Avatar
No problem, glad I could help.
Sean (SxExCx) and I are pretty much neighbors, so he helped me install my sides. My sides came pre-drilled on the bottom (bought from Arch), so I just used the same OEM bolts. Some holes were slightly off a bit, but it pretty much bolted up just like the stock sides. We did however have to drill the holes on the door jamb part. It helps if you have someone hold the side in place while the other drills the holes. You pretty much use all the stock points to hold it up.
I sure hope your sides came pre-drilled, or at least have access to a lift. I can't imagine how difficult it would be to have to drill the bottom holes alone lol. Lemme know if you need anymore details. Good luck man!
Old Jun 16, 2010 | 07:44 AM
vp-g's Avatar
looks good mine is all wave not stright like yours..
Old Jun 16, 2010 | 08:20 AM
Thanks for all the help buddy! I dont think mine are pre drilled but it shouldnt be hard! Ill let you know if i need anything! Thanks again!
Old Jun 16, 2010 | 09:49 AM
cdubel01's Avatar
CLUB MODERATOR
mine weren't predrilled, but had indentions almost exactly where the wholes needed to be, so it wasn't too difficult to know where to drill....
Old Jun 16, 2010 | 10:25 AM
What about the part of the skirt just behind the front tire in the wheel well and just infront of the rear tire in the wheel well? Did you have to predrill those also?
