Strafe Automotive Trunk Intstall
Old Nov 1, 2010 | 11:34 AM
erral's Avatar
I just got the Strafe trunk and I didn't see any threads on how to install it. Anyone know how to install it or have a DIY?
Old Nov 1, 2010 | 11:36 AM
naughty240's Avatar
What don't you understand? Coupe or sedan?
Old Nov 1, 2010 | 11:37 AM
ilovez33's Avatar
Unbolt old Trunk.......Bolt up new Trunk. Close to check functionality.....Done :-)
LordFappington's Avatar
Its pretty easy you need a torx 28 head to unscrew the bolts, remove the wire harness, take out the trunklid liner, remove the locker, put all those on the strafe. Pop only one of the struts off and install the new one.
Old Nov 1, 2010 | 11:50 AM
erral's Avatar
i have the coupe and found one. I just dont know about the holes i have to dill now
Old Nov 1, 2010 | 11:54 AM
You need to get a unibit for the holes.
Old Nov 1, 2010 | 11:56 AM
erral's Avatar
and where do i drill?
Old Nov 1, 2010 | 11:58 AM
there are indentions where the holes should be
Old Nov 1, 2010 | 12:04 PM
erral's Avatar
ah alright thanks
Old Nov 1, 2010 | 12:08 PM
look at your old lid for reference if you are still unsure. The bolting points are predrilled, but the holes for the liner are not.
Old Nov 1, 2010 | 12:12 PM
erral's Avatar
ok I am going to test fit tomorrow
Old Nov 1, 2010 | 01:18 PM
naughty240's Avatar
Here is how I did the liner. Just put tape under where the clip holes are, make with a sharpie and outline anything else. Then drill
Old Nov 5, 2010 | 12:11 PM
erral's Avatar
Thanks, figured it out, i thought it was going to be much harder. what color should i paint it?
Old Nov 5, 2010 | 12:17 PM
If youre not heavily modified I suggest painting it the stock color.
Old Nov 5, 2010 | 12:31 PM
erral's Avatar
i think it would be pretty cool to fade to cf, but thats super difficult... maybe paint to the lip and leave that cf
