compass led replacement
Old Feb 20, 2011 | 02:05 PM
jwin100's Avatar
So i took out the A/C,compass,airbag console in the dash and went to replace the LEDs in it and i started with the compass section then went to test it out and they werent working. So i then replaced the airbag light and it worked just fine. I've replaced other LEDs in my car on the door switches and what not and never had a problem. is it possible to blow that section of the board with to much heat?
Old Feb 20, 2011 | 04:33 PM
GTRskyline.'s Avatar
Heat? The voltage may need to be geared down or the amps may be wrong
Old Mar 2, 2011 | 11:39 AM
jwin100's Avatar
all that is fine. ive done all the door switched and they all worked.
Old Mar 2, 2011 | 11:41 AM
jwin100's Avatar
the only other thing i can think of is that all the LEDs are bad from the get go but i highly doubt that cinsidering i tried about 6 of them. could the C notch on the LED be backwards?
snic09
Nov 8, 2017 01:46 PM
miata007
Aug 17, 2015 04:36 PM
35reilly
Drivetrain
Aug 6, 2015 12:40 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
itschuckster
Jul 25, 2015 08:07 AM
