04 to 06 Headlights
Old Apr 6, 2011 | 07:59 AM
SINNER_G's Avatar
04 to 06 Headlights
Hey guys,
I have a 04 G coupe and i can get a really good deal on 06 headlights.
question is what is the major diffrent between the wiring?
I know i can use the 04 wiring for these lights minus the landing strip right?
And i can switch the bulbs for the top projectors but what about low beams
and fogs? is there something i can do to switch those over to hid's as well?
can someone help me here i dont wanna miss out on this deal but i also want complete hid's on the new setup no Hallowgens
Old Apr 6, 2011 | 08:28 AM
antodiaz's Avatar
Everything is a plug and play. Switch the old ballast to the new headlight and re-use all your old bulbs.
Old Apr 6, 2011 | 08:32 AM
SINNER_G's Avatar
Thanks for the quick reply,
My question is if i want to hid's for the low's can that be done i dont like the hallogen's on my car as it is so what do i need to do any help would be great what ever wiring i need to get or change or adapters let me know
Old Apr 6, 2011 | 08:39 AM
antodiaz's Avatar
If you want to put HIDs on your fogs all you need to do is buy a HID kit and it plugs to the factory just need to find a good place to put the ballasts. go to www.sylvania.com to check the fogs bulb size. Is not hard at all I did it on my wife's camry.
Old Apr 6, 2011 | 08:41 AM
SINNER_G's Avatar
what about the ummm what it it by the low beam on the 06 the city light? is that where the landing strip light goes now?
Old Apr 9, 2011 | 02:25 PM
das stig's Avatar
good luck.... just did this on my car along with a retrofit, custom paint, new lenses (for the projectors, leds, and all new bulbs. But unless you have the wiring harness for the newer headlights you have to solder and rewire almost everything ..... This is because the blinker, highbeams (bi-xenon cutoff), DRL, and fog are all different between the two lights. Although if you are just need a new ballast and thats it then yes its just plug and play. hit me up on pm if you have any questions I can walk you through it.
Old Apr 12, 2011 | 08:50 AM
rcdash's Avatar
^ not sure what you're talking about, but going from 04 to 06 is plug and play 100%. No rewiring at all. The 04 ballast transfers right over.
Old Apr 12, 2011 | 10:06 AM
das stig's Avatar
correct, if you are just transferring over ballasts then plug n play, but i said in my last post if you put an 04 wiring harness in an 06 it is far from plug n play. read my post again. and if you need wiring diagrams for both years i have them too....
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
