Heated Seat Light Problem
Old Apr 29, 2011 | 04:06 AM
gradybear's Avatar
My heated seat light went out and I didn't know how to remove it from the center console. Does anyone know how to remove it ? I have researched on the site and I only found the instruction about how to replace the light bulb itself, but there is no instruction to move the center console around the shifter. Can anyone teach me how to remove it ? How do I get to the actually heated seat switch ? Please help !!
Old Apr 29, 2011 | 04:59 PM
Enron's Avatar
it's really easy. The first day i had mine, i actually pushed the switch too hard and jammed it down into the center console.
1st of all, you have to remove the shifter. This is a piece of cake. The plastic piece at the bottom of the shift **** slides down - just grip it and pull downwards, it comes right off. Then there is a C-clip holding the shifter onto the stem - pull that out and the shifter **** comes right off. Now all you have to do is grab the top of the center console and pull up/out, it comes right off easily. You should now be able to access the heated seat switch.
Old Apr 29, 2011 | 05:13 PM
gradybear's Avatar
Is it possible for you to post some pics as DIY step by step ? Because I am scared that I might brake anything while I am doing it ...
Old Apr 30, 2011 | 12:49 PM
Keggr626's Avatar
Youtube has a great video showing how
Old May 1, 2011 | 03:58 AM
gradybear's Avatar
Thank you.
Do you have the link for that Youtube video ?
Is it possible for you to post it on here ?
Old May 1, 2011 | 01:14 PM
Keggr626's Avatar
See if this works
http://www.youtube.com/watch?feature...&v=Ql1nyPFbSpw
Old May 2, 2011 | 03:25 AM
gradybear's Avatar
Thanks alot man !
I am going to try it this weekend to see if it works.
Old May 5, 2011 | 09:57 PM
phisig's Avatar
Mine is out too, anyone know what size bulb or led we need inside the switch?
arora_g35
Apr 16, 2026 02:52 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Rokafor
Jul 29, 2015 11:50 PM
vstypicals
Jul 20, 2015 10:55 PM
