Carbon Fiber B pillars
Old Feb 12, 2005 | 01:47 AM
2crz4u's Avatar
Originally Posted by RugRatCoupe
Are you sure you're not talking about C-Pillars? If so, you may have meant my car. I believe typically Sedans only have B-Pillars(the vertical post separating the front & rear window)...anyway Here's a few pics of mine, I think it gives the G more of a flowing profile. Instead of the blunt vertical line at the rear passenger window...
********EXTERIOR-MODS********
Carbon Fiber C-Pillars, Rebadged SKYLINE/NISMO Emblems, Blacked-Out Lower Rear Exhaust Fascia, JDM Clear Corners w/PIAA LED's, PIAA Clearance Bulbs, Brushed Alum.Finished Front Grill, ANTI-PHOTO & LASER Tag, JDM Battery Cover, Polished Cam Covers, Carbon-Fiber Finished MAF...
********INTERIOR-MODS********
FIVE-SEAT CONVERSION w/ Lap Belts & Interchangable Pad or Rear Seat Console, Hide-Away PASSPORT (G-Timer), 2004 Front Console w/Arm Rest, 35% Window Tint, NISSAN Drilled Pedals, NISMO Shift ****, NISMO seatbelt Pads, SKYLINE Door Sills, Skyline Trunk Mat, Remote Window-Up Mod, VDC Memory Mod...
Do you have any pictures of the interior. Want to see what it looks like with the conversion from a 4 to 5 seater. I have a 05 wouldn't mind doing that to mine.
Old Feb 12, 2005 | 01:18 PM
RugRatCoupe's Avatar
RugRatCoupe
20 Year Member
Originally Posted by pdjafari
ahhh yes, maybe it was C pillars...where can they be purchased and approx how much please??!!!
As far as I know, no one is making these. I'm talking to a Company now that may make these for me in a higher quality finished product.
The C-Pillars in the Pics I made myself. First, I laid out a tape pin stripe first to continue the lines of the upper & lower window moldings, then I laid a piece of paper over the stripping and traced out a template. Then I cut a piece of 3M tape backed Carbon Fiber from the template and finished the edges off with 1/4" black striping tape.
I used Lockhart/Phillips 12" x 12" sheets part# 901-120 which is a real Carbon Fiber weave mounted on a 468MP 3M adhesive backing...
Old Feb 12, 2005 | 01:39 PM
RugRatCoupe
20 Year Member
I took my G to an Upholstery shop had them measure the rear seat console and make me a pad for a middle seat position. It just presses in between the rear seats.
I have 3 kids, so every once in a while I might have to use the G for the whole family (5 of us). So this just incresses the practicality of the car in case our Honda Odyssey is in the shop or something...
I took out the rear seat & attached Infiniti Lap belts(from I believe an early i 20 or QX4) to the TWO existing seat belt ANCHOR points, so it basically looks factory...
Old Feb 12, 2005 | 03:01 PM
2crz4u's Avatar
Thanks for the picture. That is the whole reason I wanted to get the back seat to convert into a 3 seater because of my kids. Looks great.
Old Feb 12, 2005 | 03:55 PM
beangrower's Avatar
that's sweet!! how much did that cost you? i think that would be a popular mod to sell
Old Jul 11, 2005 | 09:04 PM
Jason B's Avatar
We can do these for the coupe, but would need a template. From what I can see, the 2005 coupe side windows have changed their shape? Is this true?
Here are the ones we did on the m45 sedan, and will work on G35 "Sedan"
https://g35driver.com/forums/showthr...hlight=pillars
Old Jul 11, 2005 | 10:55 PM
BirdMan's Avatar
Jason if you can make these for the Coupe and they'd look similar to Rugrat's, I'd definitely be in.
Old Jul 12, 2005 | 04:23 AM
truplay8's Avatar
THE BATMOBILE
me to
Old Jul 12, 2005 | 03:30 PM
G35MR2's Avatar
Try giving CFTYPE.com a ring. They accually are sponsering my MR2, they do sick work.
Picture Share
Feb 4, 2018 12:41 PM
vQFamily
Sep 30, 2015 01:17 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
