Jdm vs. Metra double din kit?
Old May 10, 2012 | 01:38 PM
Kaishih's Avatar
Please take a picture theory
Old May 10, 2012 | 02:06 PM
SeanRoss's Avatar
that JDM pic is saying
Forbidden
You don't have permission to access /images/install/26.jpg on this server.
anybody have a close up pic of it like the metra kit up there?
Old May 10, 2012 | 02:30 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
here is the Double Din JDM prior to install
Old May 11, 2012 | 01:18 AM
Garage Kansai's Avatar
So does the jdm kit loose the split driver/passenger control
Old May 15, 2012 | 01:06 PM
ccharlton's Avatar
The JDM kit doesn't come with it installed but if you can find the right installer or follow one of the guides here on the forums you can remove it from your old A/C controller and resolder it on to the new one. Here'e a pic of the JDM dash kit with the dual climate control button.
I had mine done at Beach Autosound in Huntington Beach.
Old May 19, 2012 | 08:58 PM
twitch's Avatar
The plastic on the Metra kit is cheap. The screws that hold the top plastic tab, which screws in under the clock, is very flimsy. The fitment is OK but not perfect. And the worst aesthetic issue I found was with the vertical plastic pieces on the outer ends of the A/C vents. I have the silver trim with black dashboard. The stock pieces on the radio kit are black (look at JDM pics) and the Metra is silver. It looks dumb to have the black A/C vent | a silver strip | black dashboard. The silver paint matched OK but it was a tad darker in some spots.
The actual A/C buttons didn’t bother me terribly. What was annoying is that every couple of minutes all of the led’s on the buttons would flash. It wasn’t very bright but annoying nonetheless.
Given I had the problems with the screws not holding great I decided to put a dab of loctite blue (not the heavy duty product) on each screw. After I was complete my forearm brushed against the top mounting tab and it fell off. The loctite disintegrated the plastic. The A/C controls and the top storage compartment just fell out. Now I’ve used this loctite on plenty of plastics such as R/C car pieces. Not once did it ever eat plastic like this. The funny part is that the plastic tabs on the storage compartment were not affected at all and they did get loctite on them.
Oh well, I can’t blame the loctite issue on the kit itself since it was my fault. Just be aware that you cannot use loctite on this plastic.
Since all of the screw holes were screwed I was out of luck and couldn’t use that kit. If it weren’t for this issue I would have stuck with the Metra kit even if it wasn’t perfect. I tried to save a few bucks by using the Metra kit but ended up wasting about $150 as I purchased the JDM version from Phil now.
jsimonk
Dec 22, 2023 03:49 PM
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
Crappyday
Aug 27, 2015 10:26 PM
CHI-TOWNG35
Aug 19, 2015 11:47 AM
RA081024
Aug 18, 2015 07:03 AM
