I Need DIY for Aerocatch FLUSH PLUS install on Seibon hood
Old Jan 28, 2013 | 11:02 PM
FairladyBlue1's Avatar
Lightbulb I Need DIY for Aerocatch FLUSH PLUS install on Seibon hood
Hey Everyone,
I've been looking forever to find a DIY that shows how to install aerocatch hood pins and the right mounting place for my 04 g35 coupe, I've got a Seibon TS hood.
Does anyone know where I'd be able to find one? I've found one for an altima but its obviously not the same vehicle...I've seen tons of demand from lots of members wanting the same DIY and I know theres lot of poeple out there that have done it, help a brotha out!
Thanks!
Old Jan 31, 2013 | 02:12 AM
bump
Old Feb 2, 2013 | 01:01 PM
guitarrocker98's Avatar
As far as I k ow there isn't one. They are not a hard install, but lining up the hood is a pain, and check 2-3 times before you drill your pins.
Old Feb 2, 2013 | 05:28 PM
suprasam's Avatar
I used a diy from an 240sx a few years ago.
There are two holes in the the front composite member that are equidistant from the headlights and were the best holes for me. I installed the pins first and made sure they were the same distance front to back.
Then I used some clay on the pins and push the hood down to mark the drill points. Use several layers of painters tape on the topside before you drill or cut. Once you drill your hole then you lay down the template and trace it out. Dremel cut inside of the template lines with the cutoff wheels in "square" chunks from the straight edges then use a sanding wheel for the round edges.
I had it easy with the VIS hood because I could line up the latches on the edge of the vents. I will take a few pics and post them of where the pins are and such. The biggest thing with anything like this is verifying your measurements.
Old Feb 2, 2013 | 06:55 PM
Thumbs up
Ok cool that would help. I think the biggest thing is the placement of where you anchor your hood pins onto under the hood, like on a support or something? The guy I took it to put on the hood didnt have experience with these types of installs and he said the aerocatch pins would be on a weird curve of the hood and the plus flush isn't flexible so he was scared he was gonna crack the hood. So I decided to wait, the hood is pretty tight to the latch right now, it feels solid when its hood. But I don't want to risk it.
If you had pictures that would help for sure.
Old Feb 2, 2013 | 06:56 PM
it feels solid when its down*
Old Feb 3, 2013 | 11:49 AM
suprasam's Avatar
Here are some pics. I hope they help. FYI I use my factory latch as well, but you cant be too sure with these aftermarket hoods so the latches are nice too.
Wide shot so you can see where both pins are.
Driver's side
passenger's side
latch open
profile. My hood has a high slope too. If you can see in the previous pic, you can just make the pin hole bigger on the black part to accommodate a higher angle.
Here is a pic to show how they line up on my hood.
Old Feb 3, 2013 | 08:10 PM
Thumbs up
Driver's side
passenger's side
latch open
Thanks! Thats really helpfull. So you said to make the hole on the outside of the latch bigger to accomodate steeper angles eh? Thats good to note.
Do you know anything about the way the hood pin latches are suppose to go? It shows you have them sideways, I think Aerocatch recommends the big part towards the windshield.
But in this picture its different.
Ps. Thats a slick looking G. I just bought a pair of the upgraded projectors for my 04 G. I like what you've done with them
Old Feb 3, 2013 | 08:50 PM
suprasam's Avatar
yea make the hole that the pin goes in on the bottom.of the latch bigger for the angle. also look into password jdm mounting brackets. i think they are worth it
i dont think it matters which direction you put them.on. just whatever is best your setup.
Old Feb 4, 2013 | 04:31 AM
Yeah I looked into them. They have pretty good instructions on their website also. I'm going to buy them, just gotta becareful where you put em I guess, says it can create flat spots.
Did you install on your car?
Old Feb 4, 2013 | 07:33 AM
suprasam's Avatar
yeah i did the install. i was nervous when i started the first cut but they turned out how i wanted. it helped i had the vents as a reference point.
Old May 23, 2013 | 10:38 PM
ItsA..Gthing's Avatar
So did you use mounting brackets? If so does it really cut down on install time..?
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
yassy
Aug 9, 2015 07:31 PM
Jussaku
Aug 4, 2015 12:45 PM
RedBaronK
Jul 27, 2015 06:25 PM
