Headliner help!!
Old Jun 4, 2013 | 01:19 PM
jo dude's Avatar
Exclamation Headliner help!!
I JUST REMOVED MY HEADLINER TO PUT SOME DYNAMAT ON THE ROOF AND WHEN I PLUGGED IN THE SUNROOF SWITCH, THE MAP LIGHTS WORK BUT THE SUNROOF SWITCH DOESNT
IS THERE SOMETHING YOU HAVE TO RESET LIKE THE WINDOW'S AUTO UP AND DOWN???
PLEASE HELP!!! DOMO
Old Jun 4, 2013 | 01:48 PM
lexstart's Avatar
man, why screaming? no much experience with this but... have you tried to remove the ground from the battery for like 10 mins?
Old Jun 4, 2013 | 02:01 PM
jo dude's Avatar
my bad, loL...im juss a liL nervise wen it comes to stuff not working...
no i havent as yet...but i will
Old Jun 4, 2013 | 02:55 PM
jo dude's Avatar
iT worked for a liL biT an then continued dynamating an now it doesnt work again
Old Jun 4, 2013 | 03:40 PM
lexstart's Avatar
try this, might work.
https://g35driver.com/forums/g35-cou...f-problem.html
Old Jun 4, 2013 | 04:18 PM
jo dude's Avatar
I thought that would work...but it diDnt...
I checked all the wires...i am getting a good ground an power to the switch and the motor...idk wht else jt could b
Old Jun 4, 2013 | 08:17 PM
SergeantRed's Avatar
If you have a multimeter check to see if the switch even has power. If not, probably a fuse. There's a chance you grounded the positive during removal. Did you pull too hard on the components in the headliner and thus ripped a wire?
Old Jun 4, 2013 | 11:35 PM
jo dude's Avatar
the switch and the sunroof motor both have power...and when i press the switch forward, one wire get power, but nothing happens by the sunroof motor....
and when i put it in reverse nothing happens..
tiguy99
Mar 1, 2016 11:42 AM
GLuXuRy
Interior
Mar 29, 2006 11:35 AM
MiloX
May 31, 2005 08:35 PM
