04’ G35 Coupe Window
Old Jul 12, 2020 | 10:14 PM
JG35atl's Avatar
G35 Coupe
I recently replaced the window regulator/motor on both doors. The passenger side closes flush while, but the driver side doesn’t. Would the weather stripping cause it to close short of flush? Or a bad A pillar? The window does roll down and up correctly, just doesn’t close flush and water can drip during rainy days and wind noise can be heard while driving. Any advice or suggestions would be helpful.
Old Jul 17, 2020 | 03:33 PM
cuzin.danny's Avatar
INFINITI G35 Coupe 6MT w/Brembo's
There are two gold colored screws that protrude on the lower edges of the cover. What you can do is, with the door panel removed, close the door and raise the window all the way up. Have someone take a look from the outside to make sure it's sitting flush as you adjust the screws with a flat head screwdriver.
Old Aug 3, 2020 | 08:54 PM
Jeffreybonilla5's Avatar
Late but also sounds like u need to do a window motor relearn, so the motor learns the top and bottom limit, plenty of vids on youtube
leo38cheng
Nov 12, 2015 06:49 PM
Jussaku
Interior
Jul 29, 2015 04:13 PM
chris_u_diaz
Dec 15, 2010 09:53 AM
traian
Feb 24, 2010 11:42 AM
TSarra
Nov 3, 2008 04:01 AM
