how to modify signal lights to only turn on when signalling?
#31
The LEDs are pretty damn bright, but I don't think they are quite as bright as the stock ones. Without the load Resistor, you'd have a fast flash, like if bulb was out. Even though they aren't as bright, I like the way they look. They gather a lot of attention especially since I have LEDs in my sidemarker (made that into a blinker as well). No I don't have the rears done yet. That's my next project. I'll be using the same 7440 15-LED bulbs but in red.
Originally Posted by RST531
borahatch are the leds as bright when signaling as the stock bulb when signaling? also what would happen if i didnt get the Load Resistor kit? and did you also do the rear turn signals too? if so how do they look? i rather have leds also instead those damn bulbs.
#32
Crucial dude
on
Not hard put u can reach the passenger side under the hood, but the driver side u will need to go through the wheelwell. I recommend to use the electrical tape method. I couldnt wait for mornin so i just tried to grind them off but i cut to much and the bulb turned smoky inside, but if your careful with a dremal (which i didnt find mine to use) just cut the connections.
here the link to imagestation where i just put up the pixs. (u will need to sign up)
http://www.imagestation.com/album/pi...?id=2129587995
#33
#36
#37
Crucial dude
on
All you guys are doing really is replacing the dual filament bulb with a single filament bulb. The stock 03-05 bulb is a dual filament 7443 bulb, if you just go buy a 7440 bulb then you will get the same effect without having to dremel or cut stock wires.
#38
#40
u cant use the single fitment bulb because it wont fit in the socket, waste of money...just take out the dual fitment bulb inside ur headlights and bend the 2middle wires till it breaks off and put it back in. keep the 2remaining outside wires intact...no need to tape and its a free diy lol
#41
