topsecret wide body kit?
Old Aug 27, 2005 | 10:12 PM
SiLvErG3585's Avatar
I just had a few questions about this kit, maybe some of ya'll have got it on your g35, but I was wondering if you have it, was the instalition simple? was there any molding, or extensive drilling involved? If anyone has one please post a pic.
Old Aug 27, 2005 | 10:26 PM
G352NV's Avatar
Never enough
Ive seen the kit being installed. Its a MAJOR job! You screw the flares into the car and then fiberglass them on. Might as well do a color change at the time of install. Your pretty much painting the car anyway.
Old Aug 28, 2005 | 12:45 AM
meatbag's Avatar
I understood that the widebody panels replace the stock ones completely so they shouldnt be screwed in ??
Old Aug 28, 2005 | 12:57 AM
G352NV's Avatar
Never enough
Naw I dont think so. You just cut a bit of the fender.
Old Aug 28, 2005 | 01:15 AM
that really sounds like a ton of pretty risky work goin on, do ya'll think that the labor would cost a fortune?
Old Aug 28, 2005 | 01:58 AM
G352NV's Avatar
Never enough
Yes about 4k including paint and install.
Old Aug 28, 2005 | 01:59 AM
CarFanatic56's Avatar
labor probably would cost fortune
Old Aug 28, 2005 | 02:03 AM
G2FAST's Avatar
Have you priced out the kit? I would say figure to spend about 10k total, kit/install/paint. Two other items to think about would be wheel size (20's) and the rear wheelwell will you cut it or leave it alone.
Old Sep 2, 2005 | 02:04 PM
nonissan's Avatar
why would you not cut the wheelwell? isn't the whole point to add biga55 rims?
Old Sep 2, 2005 | 04:55 PM
TOPSECRET2001's Avatar
Everything is bolt-on except the rear fenders. The front fenders completely replace the front ones. This work is relatively simple.
The rear fenders should be attached with rivets. Most people like to mold them to the car. Once on, to get the most wheel/tire clearance, the stock sheet metal underneath the rear fenders can be cut away. The wide fenders take the place of what you're cutting away and it is not visible so it's not a "risky" job but it is permanent. The rear fenders are the only tricky part of the kit.
carid
Aug 22, 2016 01:34 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
Machine Head
Sep 4, 2015 07:22 PM
PrestigeG35
Aug 18, 2015 04:47 PM
helalo
Aug 10, 2015 08:21 AM
