gunk and stuff on my headlights
Old Mar 26, 2006 | 04:46 PM
04Gwhiz's Avatar
my friends G was at the body shop and he got a set of new 06 projectors and he wants to sell his old 04 pair..problem is there is masking tape residue and i think filler residue and all types of dirt on it..what do people suggest I use to get the gunk off without scratching the surface..should i use any type of sand paper or abrasive?1500 grit etc...i dont want to screw up the clear glass...
Old Mar 26, 2006 | 04:55 PM
ZLUJ's Avatar
Mmhm...
DONT USE ANY TYPE OF SAND PAPER! LOLS use somethign similar to turpentine, somethign thatll eat away the stick crap but not destroy the platic.... wait for more respsonses to this thread though, becuse im not too sure.
Old Mar 26, 2006 | 05:09 PM
MikeyMike's Avatar
Rollin On Dubz
If you go to pepboys they should have some type of car cleaner thats specific for removing residue like that
Old Mar 27, 2006 | 01:29 PM
vipv35's Avatar
i suggest goo gone or goof off. u can get them at walmart.
Old Mar 27, 2006 | 01:55 PM
imalazeeass's Avatar
theres a product called plast-x. search for it you'll find many results. u can also use goo-gone or 3m general adhesive remover.
Old Mar 27, 2006 | 04:48 PM
Diesel1's Avatar
Moderator
FYI the PLASTX as mentione above should work. Just becareful trying multiple chemicals. I had the unfortunate experience of ruining a headlight on a friends G because a chemical reaction "melted" the plastic.
For the record, you can certainly wetsand the headlight assembly using 2000 or higher grit. Follow up witha polish and you lights will look better then new. Be sure if you use sandpaper that you wrap it around a sponge which will ensure even pressure. Also, be sure to keep the light and paper well lubricated.
Old Mar 27, 2006 | 05:13 PM
absolutg's Avatar
workin...
3m plastic polish or something similar to that is suggested by nissan/infiniti. i think it's the only polish they recommend for headlights...
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Learned Hand
Oct 1, 2015 09:02 AM
Batfinity
Lights
Sep 27, 2015 12:29 AM
