CF interior parts
Old Jan 1, 2010 | 07:13 PM
4drmadness's Avatar
CF interior parts
What do you guys think can be wrapped with cf for the 03-04 sedans. im talking about the interior pieces in our cars.
Old Jan 1, 2010 | 07:33 PM
Calvin's Avatar
Overglorified Altima
Anything can be wrapped. Just depends on how well you can wrap.
Old Jan 1, 2010 | 07:34 PM
Calvin's Avatar
Here are some ideas:
https://g35driver.com/forums/accesso...placement.html
Old Jan 1, 2010 | 07:54 PM
ttrank's Avatar
Grocery getter
Wrap with real carbon or vinyl?
Real carbon with bagging, anything as where with vinyl it depends on the part and how good you are.
Old Jan 7, 2010 | 04:57 PM
bmpnride's Avatar
I just had my whole center console wrapped in cf vinyl. I still need to take some pics. Came out awesome with the dry carbon weave.
Old Jan 7, 2010 | 05:10 PM
sammy_G's Avatar
i wouldnt bag interior parts.. especially plastic pieces.. they'd get crushed in the bag unless they had an alaborate jig supporting them that would be so complicated to build you might as well just make a mold off the part and then vacuum real carbon parts from that mold...
for one off pieces your best bet is wrapping by hand (wear gloves - resin alergies are a bitch)
lots and lots of wet sanding between several coats of resin is key..
also don't hesitate to put smaller parts in an oven around 200 degrees to heat cure... your parts will be twice as strong and it helps lower the viscosity of the resin right before it cures so that makes the sanding process easier...
your interior gets very hot just remember any resin or epoxy you use will likely fail above any temp they were cured at... in other words your parts can warp or break if it isnt cured properly.
good luck!
Old Jan 7, 2010 | 05:15 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ it's done all the time.
This is my 2nd gen...
Old Jan 7, 2010 | 05:20 PM
G35Papa's Avatar
Post pics Troy. I want to see it!
Old Jan 7, 2010 | 07:15 PM
4drmadness's Avatar
im getting some of the parts wrapped in cf as we speak
Old Jan 8, 2010 | 12:38 AM
bmpnride's Avatar
Here are some of the pieces I had wrapped. Looks great in person. Cant wait to get it into the car..
Old Jan 8, 2010 | 12:43 AM
G35Papa's Avatar
That came out really nice Troy. If you don't mind, PM me a price and where you got it done. Thanks
Old Jan 8, 2010 | 01:04 AM
ttrank's Avatar
Grocery getter
That looks great. Good job on the pattern matching too.
Old Jan 8, 2010 | 01:26 AM
bmpnride's Avatar
I had a local shop do it since I know it would be way better than any wrap I could do. He used the 3M vinyl which is a million times better than the othe fabric that others were using. I actually have alot of the fabric left that I never used if anyone is interested. The 3M stuff is stronger, resistant to water, easier to work with and has a more realistic weave.
Old Jan 8, 2010 | 01:32 AM
Damn^^ thAt looks sweet. Pm your price and I'll take it.
Old Jan 8, 2010 | 01:58 AM
ttrank's Avatar
Grocery getter
How much do you have left? Let me know what you have and a price shipped to 85085.
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
s8n
Jul 31, 2015 01:37 AM
s8n
Jul 30, 2015 04:47 AM
