DIY: Window motor repair
Old Jun 18, 2012 | 12:57 PM
  #61
blAk mAx's Avatar
it's not too bad. I bought a cheap set of mini screwdrivers to get the silicone out. Desoldering the 2 wires just unclip and pull up while heating the wires with the soldering iron. To pull the assembly out I pull on the plastic with needle nose pliers while heating the ends/silicone. You may need to heat the silicone/solder left at the bottom, to put housing back in. I doesn't matter if you melt the black plastic. Just don't solder the 2 wires together.
Old Nov 22, 2012 | 06:36 PM
  #62
Polishthrust's Avatar
Awesome guide!
I just replaced the brushes and my window motor works again like new. Thanks!
Old Jun 9, 2013 | 11:54 PM
  #63
ZFRED10's Avatar
Great DIY. Just did this today and now my window works flawlessly. Saved me a bunch of $$$. Picked up the brushings off eBay for $3 and already had everything else I needed. The only issue I ran into was in your pics when soddering the two wires back on you have them backwards. You have the all blue wire running to the back prong and the blue and red wire going to the front one. When I did that and installed the motor the up and down switch were reversed so I had to rip everything apart again to switch them back. Not a big deal though. Just letting you know for people doing this in the future. Thanks again!
Old Oct 6, 2013 | 09:33 PM
  #64
arekieh's Avatar
worked perfectly, thanks a lot.
Old Aug 10, 2017 | 10:57 PM
  #65
Saaif88's Avatar
I don't mean to necro this thread, but I'm trying to do this as well. Is this the same procedure for the V36? Does anyone know if these brushes will work?
http://www.ebay.ca/itm/Trinity-RC-Mo...gAAOSwhvFZK0kY
Any help would be greatly appreciated!
bananax
Sep 24, 2019 12:24 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
itgogitrev
Sep 23, 2015 07:08 PM
TNRocker
Sep 21, 2015 08:36 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
